Re: 426 hemi rocker arms
[Re: cownurse]
#1698875
11/14/14 03:38 PM
11/14/14 03:38 PM
Posts: 13,618 Marion, South Carolina [><]
an8sec70cuda
I don't know what spring pressures, but I remember HemiFred saying he ran the factory wide pad rockers for years and years on some pretty nasty roller cams.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: cownurse]
#1698876
11/14/14 07:19 PM
11/14/14 07:19 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Thanks Rich, is it you who wrote the book.
Yep.
[Re: quickd100]
#1698878
11/15/14 04:48 AM
11/15/14 04:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The problem is not strength, its consistency of the ratios. You can pick 100 rocker arms and be lucky to find a match set of 8, not the right ratio mind you but at least they would be the same ratio....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1698880
11/15/14 07:46 AM
11/15/14 07:46 AM
Posts: 6,421 nielsville, minn.
quickd100
nielsville, minn.
Very True!!! It's one of the hair pulling, cussing and screaming aspects of building a Hemi. I've got 2 sets of stock rockers one of which was a set of old superstock rockers. My intakes go from 1.63 to 1.69 ratio. The exhausts go from 1.49 to 1.53. Dave
[Re: quickd100]
#1698883
11/18/14 12:55 PM
11/18/14 12:55 PM
Posts: 13,419 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
If my math is correct, then the variation between the rockers is less than 1%. How large of an impact could that realistically have for most of us? Is that range typical of OE style rockers?
It would seem to me that the head ports would not be that consistent.(even after porting) Or the intake runners. Or the cam lobes. Etc, etc. And I doubt that many of us could set the lash within 1%. A .001" variation on a .020" lash is 5%.
The OE style rockers have proven themselves to be very durable over the decades for most of what we do with these engines. So, how much real world impact does the infamous variation have on our combos. Could it be noted on a time slip or dyno sheet? Let alone seat of the pants?
Opinions please.
Master, again and still
[Re: Cab_Burge]
#1698889
11/18/14 08:58 PM
11/18/14 08:58 PM
DaveRS23
Benton, IL.
I use to race(1974 to 1976) a 1970 426 hemi Cuda 4 speed car in NHRA stock, I ended up buying all the spare parts I could I ended up finding out later that the rocker arms on my motor had .100 net lift difference(.430 to .530) on the exhaust side and .080 (.460 to .520) on the intakes I went though five sets of rocker to get my motor legal with the stock cam specs, the ratio are horrible on the stock stuff I like to get all things equal as far as compression ratio, storke, intake and exhaust port volume, combustion chamber volume, rocker ratio, net lift at the retainers and so on
Holy crap!
So, is it worth it to have some of the rocker guys to square up the ratios on the stock rockers? I think it is like $500 or so to do it. If, like me, you already have a good set of stock rockers, would getting them trued for that kind of coin be worth it versus $2,500 or more for aftermarket ones?
This would be for a street/strip car.
Between this and the threads on addressing the intake sealing issues, I am learning a ton here.
