Page 1 of 3 1 2 3
440 source stuff #1698498
11/13/14 03:18 PM
11/13/14 03:18 PM
SC
BowtieKillr Offline OP
SC
Looking to build a stroker around 500 to 540 c.i. for bracket racing. How reliable is the 440 source stuff compared to the high $ stuff. D o you guys run there stuff and if so how do you like it.
Re: 440 source stuff [Re: BowtieKillr] #1698499
11/13/14 03:26 PM
11/13/14 03:26 PM
welcome aboard . Early on way back, source got bashed a bit & I think there were some quality control issues with their heads/water pumps which I believe have been resolved & alot of people (on here) have used their stuff with a few issues with the valve train gear but alot of people are happy with them expecially stealth heads & you need to have any mailorder stuff from anyone gone over by your local trusted/competent machinist. I'm gonna pull the trigger on a 535 RB source stroker kit (go big or go home) as soon as those slick talking lawyers in California settle up for their insured driver tboning my daily driver
Re: 440 source stuff [Re: RapidRobert] #1698500
11/13/14 03:39 PM
11/13/14 03:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Yikes Robert! I heard about that accident but never saw any pics! anyway to the OP, I haven't heard any bad rumblings on this board about their stuff in a number of years. there are a few guys that absolutely hate them but I think that's mostly because a lot of the parts aren't manufactured in the US. while I would be much happier with that also my pockets aren't deep enough. i'm gonna be pulling the trigger on their water pump/housing very soon. I've read enough recent stuff to be ok that the narrow channel issue has been addressed.
Re: 440 source stuff [Re: mikemee1331] #1698501
11/13/14 04:50 PM
11/13/14 04:50 PM
SC
SC
Well ive been a member since around 2007 her , but havent been doing anything but spectating and im ready to start putting the dart back together. Just would hate to build a stroker with 440's parts and it come apart because of parts failure. i know thats always a chance with everything you buy in racing but that would really suck big time. Still a little gun shy !!! Thanks any how guys .
Re: 440 source stuff [Re: BowtieKillr] #1698502
11/13/14 04:53 PM
11/13/14 04:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
ya might ask the question over on the racer forum...
Re: 440 source stuff [Re: BowtieKillr] #1698503
11/13/14 04:59 PM
11/13/14 04:59 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I have used source stuff and so far so good.I do check all the parts carefully.I would not use any of the valve train parts that come on the assembled heads but other than that I have no issues.
Leave the gun.......take the Cannoli's....Mike
Re: 440 source stuff [Re: mike s] #1698504
11/13/14 07:04 PM
11/13/14 07:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've bought a lot of their stuff and have had "concerns" with some of it. HOWEVER, I did buy their 528" stroker kit and other than having to fit the pins, everything checked out fine. I bought the balanced assembly but did not have that checked - what's the point, it costs the same to check it as it does to actually balance it. So on that note, you either trust them or you have it done locally.
You will hear a lot of China bashers here that have never so much as seen a 440Source part in person let alone bought one. Take their comments with a grain of salt.
Re: 440 source stuff [Re: Stanton] #1698505
11/13/14 09:59 PM
11/13/14 09:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My 500 cubic inch assembly went 275 runs in my Daytona (8.60's@155mph) before the block finally cracked. That same assembly is still going strong in a street car now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 source stuff [Re: pittsburghracer] #1698506
11/14/14 12:02 AM
11/14/14 12:02 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I bought a set of their bare stealth heads and was very happy with them. I put all comp hardware in them and surfaced the heads to lower the chamber volume a little bit. I mainly went with them because they look like a factory casting. You can't tell the difference once they're painted
Re: 440 source stuff [Re: BowtieKillr] #1698507
11/14/14 12:12 AM
11/14/14 12:12 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Here is one person's experience..
A close friend bought a pile of the source stuff building his 65 Belvedere, here are his results..
1. Ignition box, failed after 30 days
2. Valley pan, failed after 60 days
3. Water pump housing, engine ran hot switched out to the Mopar performance part no issues.
4. Oil pan, leaked replaced with a Milodon
5. Distributor, OK
6. Stealth heads, OK
7. 509 Stroker crank kit, OK
8. Adjustable rocker arms, OK
9. Mini-starter, failed after 1K miles
IMHO..
Their stroker kits and heads are fine, but the other stuff is marginal. Note that the car has <1200 street driven miles so little actual running time on the various parts.
In today's tight economy everyone want to save $ thats why we have other options such as Harbor Freight.
Just my $0.02...
Re: 440 source stuff [Re: Sinitro] #1698508
11/14/14 01:14 AM
11/14/14 01:14 AM
Kansas
Kansas
What oil pan did he have? I bought the 6qt hemi pan and haven't had any leaks on mine.
Re: 440 source stuff [Re: BEINGmeISaCRIME] #1698509
11/14/14 01:53 AM
11/14/14 01:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use their stroker kit also and its been in my car running for over three years with no problems. Most just say the piston pins are a bit tight as mine were also but I just worked them and fitted them myself. The rest checked out ok and is working good. Ron
Re: 440 source stuff [Re: BEINGmeISaCRIME] #1698510
11/14/14 02:17 AM
11/14/14 02:17 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Here U go..
There was a hairline crack in the welded seam..
Just my $0.02..
Re: 440 source stuff [Re: BowtieKillr] #1698511
11/14/14 10:59 AM
11/14/14 10:59 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Got a water pump from them, JUNK !!!! HP440 Over Heated !! Got a Mopar performance problem solved
Re: 440 source stuff [Re: TOMRR] #1698512
11/14/14 11:22 AM
11/14/14 11:22 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have a set of their heads from the first production batch, no problems. Have their oil pan as well with no problems. Bought a bunch of small knick knacks there too with no problems.
I have heard guys had problems with their roller rockers, which is not surprising when guys go and run 600 lb spring pressures on an el cheapo china rocker. I went with crane rockers instead.
Re: 440 source stuff [Re: Sinitro] #1698513
11/14/14 12:21 PM
11/14/14 12:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here U go..
Just my $0.02..
I've heard of similar problems with Milodons so I wouldn't consider this a show stopper. Honestly, I believe all oil pans come from the same place - there's no way a company could justify the cost of dies to stamp out Mopar oil pans. My guess would be Milodon makes the pans and sells to 440Source, Summit, etc who "rebrand" the pan. Likewise with the windage trays.
440Source stuff I've had/have:
distributor - sold to someone who needed it urgently
water pump - hogged out the passage but got a smokin deal on a MP piece - sold the 440Source piece
heads - sold - decided the stroker needed more flow, bought Indys
fabbed timing cover - sold - crank seal hole was offset once installed. Probably wouldn't have been an issue but I wasn't satisfied.
valley tray and holddowns - sold - didn't need them after sellin the heads
alternator and bracket kit - on the motor. This is an Andy F. kit FWIW
serpentine pulleys and belt - on the motor - very nice pieces
fluid damper - on the motor
rear oil seal kit - on the motor
complete stroker kit - in the motor
Re: 440 source stuff [Re: Stanton] #1698514
11/14/14 03:16 PM
11/14/14 03:16 PM
SC
SC
Hey Stanton , The new Super Stealth head is it Anywhere near the Indy's stuff.
Re: 440 source stuff [Re: TOMRR] #1698515
11/14/14 04:30 PM
11/14/14 04:30 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
X2
2011 Drag Pak Challenger
Re: 440 source stuff [Re: rickseeman] #1698516
11/14/14 05:23 PM
11/14/14 05:23 PM
TX
jeepers007 Offline
jeepers007  Offline
TX
The water pump issue is no longer relevant unless you buy one used. They have changed the design.
Re: 440 source stuff [Re: BowtieKillr] #1698517
11/14/14 06:05 PM
11/14/14 06:05 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Page 1 of 3 1 2 3
