69 B Body front spindels #1698161
11/13/14 12:26 AM
11/13/14 12:26 AM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
My ? is this. I have a 69 RR with disc brakes, the lower ball joint arm bolts to the spindel. I have talked to two sulppliers of oe parts and the both say that the lower ball joint arm uses thru bolts with a castle nut and carter pin. But I have seen 3 cars in the past 2 days that are like my car. Which the ball joint arm uses only a bolt and the spindel is threaded. Both suppliers told me that the setup I have is not factory? Is that correct? thanks
Re: 69 B Body front spindels [Re: stuman] #1698162
11/13/14 12:34 AM
11/13/14 12:34 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
On 1966-69 Bendix disc brake systems, for the B body cars, the spindles are Threaded, for the lower ball joint attachment. No nuts.
Drum brake spindles would use a bolt and nut.
1970 up, disc brakes would use a bolt, and nut.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 69 B Body front spindels [Re: hemi71x] #1698163
11/13/14 02:13 AM
11/13/14 02:13 AM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
thanks for the quick reply. Is there any where I can get some documention on this so I can show the 2 experts? That told me that this is not factory and we can enlighten them. RThanks again
Re: 69 B Body front spindels [Re: stuman] #1698164
11/13/14 09:26 AM
11/13/14 09:26 AM
BDW Offline
BDW  Offline
FSM?
Re: 69 B Body front spindels [Re: BDW] #1698165
11/13/14 11:31 AM
11/13/14 11:31 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Does it use the same lower ball joint as the 70. Or is it 66-69 only?
Re: 69 B Body front spindels [Re: fastmark] #1698166
11/13/14 01:47 PM
11/13/14 01:47 PM
hemi71x Offline
hemi71x  Offline
You know that old Chinese guy that said, "A picture is worth a thousand words"
Well then, here's a picture of of three left side 66-69 Bendix disc brake spindles, for the B Body line of cars, that i have in my collection, stash, hoard, accumulation, rat hole, of parts.
I still rebuild brakes, suspension, parts in my old age for extra money, from time to time.
Having some time to kill, before i have to leave for another hospital appointment, for some of my medical issues these days, i had the time to do the picture thing for you.
Re: 69 B Body front spindels [Re: fastmark] #1698167
11/13/14 03:28 PM
11/13/14 03:28 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
IIRC correctly all the lower ball joints interchange between 62 and 72 spindles on a B body.
This style I would think would be easier to change ball joints in since you do not have to remove the hub or drum assembly to get to the bolts like those with a bolt and nut combo.
...FAFO...
Re: 69 B Body front spindels [Re: skicker] #1698168
11/13/14 03:36 PM
11/13/14 03:36 PM
hemi71x Offline
hemi71x  Offline
Yes, that is correct.
Re: 69 B Body front spindels [Re: hemi71x] #1698169
11/13/14 10:11 PM
11/13/14 10:11 PM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
Thanks for all the info. going to froward this to the Experts that told me no way was the bolt on style correct
for my disc brake car.
They said they have look at 100"s of cars and have not seen a direct bolt on. Wonder what they have been looking at? Well maybe I didn't explain is correctly? I was also told that a 69 Hemi has two choke tubes on it ? Mine as onle one going to the exhaust manifold next to the heat riser. Does anyone have a pic of the choke tubes? Speaking of heat riser. Had to sit down after getting a $ on a rebuild kit. All Ireally need it the spring, does anyone sell just the spring?
Re: 69 B Body front spindels [Re: stuman] #1698170
11/13/14 10:37 PM
11/13/14 10:37 PM
hemi71x Offline
hemi71x  Offline
What was your initial problem that you were asking around about ball joint bolts?
You putting a pair of Bendix brakes back together, and don't have the bolts?
5/8 x 18 x 1 3/4 inch length.
Re: 69 B Body front spindels [Re: hemi71x] #1698171
11/15/14 08:32 PM
11/15/14 08:32 PM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
trying to find out what the correct markings where on the bolt heads for the ball joint and caliper.
Re: 69 B Body front spindels [Re: stuman] #1698172
11/15/14 08:57 PM
11/15/14 08:57 PM
hemi71x Offline
hemi71x  Offline
If you only thought to ask, when i took the picture of those three spindles, i could have told you.
But i put them away, and i can't dig them out again.
Re: 69 B Body front spindels [Re: hemi71x] #1698173
11/15/14 10:06 PM
11/15/14 10:06 PM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
thats ok I needed the pics to show the non belivers what they looked like, The bolts have a N marking in the head
Re: 69 B Body front spindels [Re: stuman] #1698174
11/15/14 10:12 PM
11/15/14 10:12 PM
hemi71x Offline
hemi71x  Offline
I guess that's why you were looking at other disc brake B Body's then.
To find markings on bolt heads.
Oh well, to each his own.
