Re: Roll cage tubing ????
[Re: sg66mopar]
#1697696
11/11/14 10:42 PM
11/11/14 10:42 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
I believe the common thickness for chromoly is: .083 and .120 is common for mild steel. Common for roll bar tubing, that is.
unions....the folks who brought you the weekend!
[Re: mac56]
#1697698
11/11/14 11:01 PM
11/11/14 11:01 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
.095 x 1.75 CM is pretty stout stuff. I haven't fooled with any but I expect it would take a decent bender to bend that. AED in Indianapolis has tubing that size. No idea what it would take to get it to you. I hope your guys know how to calibrate the sonic testers correctly. Apparently when they started using them to check bars here, they didn't. Created a lot of problems later on when they learned how to do it right. I know of more than one car that had passed a couple of times and then all of a sudden wasn't legal.
[Re: mac56]
#1697701
11/12/14 02:06 AM
11/12/14 02:06 AM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
You might want to look at one of these of they are going to sonic them they might also see if the meet some type of spec ??????????? Spec #/_______Tractors/__________________________Current Revision Date/__Price ($US) 47.1/ Driver Roll Cage for Use on 7,000 To 10,000 lbs. Tractors/ June 26, 1998/ 38.00 47.2/ Driver Roll Cage for Use on Tractors, Less Than 6,000 lbs./ June 26, 1998/ 38.00 47.3/ Driver Roll Cage for Use on “Mini-Rod” Tractors, Less Than 2,000 lbs./ June 26, 1998/ 38.00
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1697702
11/12/14 04:23 AM
11/12/14 04:23 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Also be on the lookout for fake CM, there was a bunch imported from China that did not meet spec even though it was labeled 4130 normalized...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1697703
11/12/14 09:08 AM
11/12/14 09:08 AM
Posts: 1,999 s. e. pa.
calrobb2000
s. e. pa.
hi how do you know if it is fake 4130 ?? thank you !
[Re: W.I.N. Racing]
#1697704
11/12/14 09:26 AM
11/12/14 09:26 AM
Posts: 976 ontario canada
mac56
ontario canada
Bill that is exactly why we are changing the cage on this tractor. It has to meet the SFI 47.3 spec which is 1.75 .095 chromoly or 1.875 .083 mild which is over kill for the class because this spec is for ntpa 2000 hp minis. the club requesting this does not allow that class of tractor. It is like putting 8.90 cage in a twelve second car. The 2 choices seem out of wack to me be I haven't looked up how the 2 choices compare to each other.
[Re: mac56]
#1697707
11/12/14 09:40 PM
11/12/14 09:40 PM
W.I.N. Racing
Byron, NY
Problem is you need to buy both cert books to get the details...but cheaper in the long run vs wasting time and tube
[Re: mac56]
#1697709
11/12/14 10:32 PM
11/12/14 10:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1.75 is as common as it gets. Any chassis shop will have dies to bend that as long as the machine will do it. I have no idea where you would get 1.875 bent. Not a chassis shop that I know of.
