Roll cage tubing ???? #1697692
11/11/14 09:18 PM
11/11/14 09:18 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
How do they check the thickness and material for a race car cage? We have 1 pulling club in Quebec that is going to start checking cages. There are to option for mild steel and chromoly. I believe they are going to use a sonic checker. Can they determine material this way or just thickness?
Re: Roll cage tubing ???? [Re: mac56] #1697693
11/11/14 09:47 PM
11/11/14 09:47 PM
sg66mopar Offline
sg66mopar  Offline
Just thickness with the sonic tester. They do have ways (usually chemical) to check the type of steel.
If it's like our local NHRA guys, they took my word for it.
Chromoly is stenciled from the steel mill so if it's not painted or coated they can see it's Moly.
Re: Roll cage tubing ???? [Re: sg66mopar] #1697694
11/11/14 10:05 PM
11/11/14 10:05 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Ok thanks. In our sport near all chassis are painted due to the enviorment we pull in.
Re: Roll cage tubing ???? [Re: mac56] #1697695
11/11/14 10:38 PM
11/11/14 10:38 PM
sg66mopar Offline
sg66mopar  Offline
Generally speaking the moly tubing is available in different thicknesses than you would see with mild steel. If the chassis inspector is familiar with the common mild and moly wall thicknesses they'll probably know what they're looking at.
Re: Roll cage tubing ???? [Re: sg66mopar] #1697696
11/11/14 10:42 PM
11/11/14 10:42 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
I believe the common thickness for chromoly is: .083 and .120 is common for mild steel.
Common for roll bar tubing, that is.
unions....the folks who brought you the weekend!
Re: Roll cage tubing ???? [Re: 68-scatpack-rt] #1697697
11/11/14 10:51 PM
11/11/14 10:51 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
The spec is .095 1.75 chromoly which I can buy in mild steel. Even though that is the spec I havent found that in chromoly.
Re: Roll cage tubing ???? [Re: mac56] #1697698
11/11/14 11:01 PM
11/11/14 11:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
.095 x 1.75 CM is pretty stout stuff. I haven't fooled with any but I expect it would take a decent bender to bend that. AED in Indianapolis has tubing that size. No idea what it would take to get it to you. I hope your guys know how to calibrate the sonic testers correctly. Apparently when they started using them to check bars here, they didn't. Created a lot of problems later on when they learned how to do it right. I know of more than one car that had passed a couple of times and then all of a sudden wasn't legal.
Re: Roll cage tubing ???? [Re: CMcAllister] #1697699
11/11/14 11:15 PM
11/11/14 11:15 PM
sg66mopar Offline
sg66mopar  Offline
I bought some moly from onlinemetals.com and I believe they have the .095 x 1.75 tubing.
Re: Roll cage tubing ???? [Re: sg66mopar] #1697700
11/11/14 11:35 PM
11/11/14 11:35 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Im not far from the border so I just come across to pick stuff up so it isnt bad getting anything from the lower 48
Re: Roll cage tubing ???? [Re: mac56] #1697701
11/12/14 02:06 AM
11/12/14 02:06 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
You might want to look at one of these of they are going to sonic them they might also see if the meet some type of spec ???????????
Spec #/_______Tractors/__________________________Current Revision Date/__Price ($US)
47.1/ Driver Roll Cage for Use on 7,000 To 10,000 lbs. Tractors/ June 26, 1998/ 38.00
47.2/ Driver Roll Cage for Use on Tractors, Less Than 6,000 lbs./ June 26, 1998/ 38.00
47.3/ Driver Roll Cage for Use on “Mini-Rod” Tractors, Less Than 2,000 lbs./ June 26, 1998/ 38.00
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Roll cage tubing ???? [Re: W.I.N. Racing] #1697702
11/12/14 04:23 AM
11/12/14 04:23 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Also be on the lookout for fake CM, there was a bunch imported from China that did not meet spec even though it was labeled 4130 normalized...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Roll cage tubing ???? [Re: astjp2] #1697703
11/12/14 09:08 AM
11/12/14 09:08 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
how do you know if it is fake 4130 ??
thank you !
Re: Roll cage tubing ???? [Re: W.I.N. Racing] #1697704
11/12/14 09:26 AM
11/12/14 09:26 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Bill that is exactly why we are changing the cage on this tractor. It has to meet the SFI 47.3 spec which is 1.75 .095 chromoly or 1.875 .083 mild which is over kill for the class because this spec is for ntpa 2000 hp minis. the club requesting this does not allow that class of tractor. It is like putting 8.90 cage in a twelve second car. The 2 choices seem out of wack to me be I haven't looked up how the 2 choices compare to each other.
Re: Roll cage tubing ???? [Re: calrobb2000] #1697705
11/12/14 01:45 PM
11/12/14 01:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
hi
thank you !
It's in Chinese?
Or its wrapped like chopsticks?
Re: Roll cage tubing ???? [Re: calrobb2000] #1697706
11/12/14 05:54 PM
11/12/14 05:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
hi
thank you !
Stay away from the Chinese stuff. You get what you pay for. Always ask where is it made.
Re: Roll cage tubing ???? [Re: mac56] #1697707
11/12/14 09:40 PM
11/12/14 09:40 PM
Byron, NY
Byron, NY
Problem is you need to buy both cert books to get the details...but cheaper in the long run vs wasting time and tube
'60 Willys CJ5
Re: Roll cage tubing ???? [Re: W.I.N. Racing] #1697708
11/12/14 10:01 PM
11/12/14 10:01 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I have a copy of the section Bill. A friend purchased it a while back.
Re: Roll cage tubing ???? [Re: mac56] #1697709
11/12/14 10:32 PM
11/12/14 10:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
1.75 is as common as it gets. Any chassis shop will have dies to bend that as long as the machine will do it. I have no idea where you would get 1.875 bent. Not a chassis shop that I know of.
Re: Roll cage tubing ???? [Re: CMcAllister] #1697710
11/12/14 10:45 PM
11/12/14 10:45 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
What my buddy did was went with 2 inch .083 wall and that satisfied the sfi spec.
Re: Roll cage tubing ???? [Re: calrobb2000] #1697711
11/12/14 10:52 PM
11/12/14 10:52 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ask for made in the USA certification paperwork, any reputable supplier will provide it for a small fee, worth the effort.
http://aircraftproducts.wicksaircraft.co...amp;pagesize=50
certified good chit!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
