Should I buy this 8 3/4 sure grip center chunk? #1697361
11/11/14 12:22 AM
11/11/14 12:22 AM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
I can get this locally for about $300 - not sure if its worth the buy?
489 case with 2.89 gears open diff + a used sure grip unit 3.23 with a few broken teeth...see pic please..
Seller says the SG is good, he got it with other parts...how can I tell?
Or cause the teeth broke just run away...
Plaz
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697362
11/11/14 12:26 AM
11/11/14 12:26 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I don't see a pic. Does the s/g have clutches?
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697363
11/11/14 12:31 AM
11/11/14 12:31 AM
plazomat Offline OP
plazomat  Offline OP
Second try..
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697364
11/11/14 12:41 AM
11/11/14 12:41 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I would say no
That's a cone type sure grip and while it's not a bad unit it's not rebuild able Well it sorta is. To have to do some machining and it's good to go again. For awhile.
Unless you need the other items id pass. The ratios are poor and one is broken so it makes me question the condition of the s/g.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: NTOLERANCE] #1697365
11/11/14 12:44 AM
11/11/14 12:44 AM
plazomat Offline OP
plazomat  Offline OP
Thanks for the help...I'll pass.
Plaz
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697366
11/11/14 12:44 AM
11/11/14 12:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
UNLESS you can do a tension test to asses the integrity of the differential, you have to play it safe and assume that the CONE diff is worn out. I'd never buy a used cone diff without a test.
My axle guy puts the diff in a vise and locks one axle down, then tries to spin the other axle with a torque wrench. If the unit slips at anything under 80 ft/lbs, the unit is on its way out.
CONE differentials can be rebuilt but there are some drawbacks to that. It is because of this that even the factory suggested total replacement in the event of excessive wear.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: Kern Dog] #1697367
11/11/14 12:47 AM
11/11/14 12:47 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Can't you buy a new sure grip for $400 or so?
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: NTOLERANCE] #1697368
11/11/14 12:51 AM
11/11/14 12:51 AM
Kirkland, Washington
Pacnorthcuda Offline
They've been on back order for over a year...don't know why, Doc Diff would know.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: Pacnorthcuda] #1697369
11/11/14 12:59 AM
11/11/14 12:59 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
New 8.75" (power-lock) clutch internals are available, but the carriers are not. I'm currently having my own carriers made by a different manufacturer.
Complete units should be available by spring.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: DoctorDiff] #1697370
11/11/14 03:47 AM
11/11/14 03:47 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I agree with above, don't buy it.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: 70blackfish] #1697371
11/11/14 11:42 AM
11/11/14 11:42 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
I would take this guys advise. Watch towards the end of the vid. around 3.35 on. That's what I'd do!
http://www.youtube.com/watch?v=ZfL4xKQeSfo
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: bigblock340power] #1697372
11/11/14 06:53 PM
11/11/14 06:53 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
If its a 2.89, yes, its one of one
18/52 R/P tooth count?
Otherwise, No, plenty of other bigger fish in the pond.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: jcc] #1697373
11/11/14 07:41 PM
11/11/14 07:41 PM
plazomat Offline OP
plazomat  Offline OP
Oh man how many of you caught that one and didn't call me out.....
Plaz
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697374
11/11/14 09:17 PM
11/11/14 09:17 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Not worth 300, I'd say the SG unit it worth 100. Value the rest at what you want.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: GTX MATT] #1697375
11/12/14 12:38 AM
11/12/14 12:38 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the sure grip may be worth $100 but only if it's not junk ... but it's a cone type so it's already JUNK by design.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: JohnRR] #1697376
11/12/14 02:41 AM
11/12/14 02:41 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Haven't you read all these posts about cone types surviving 600 hp for years?
I agree. Junk. The powr loc designed clutch type is the way to go for performance
That being said for a driver stock engine car. Eh doesn't matter I guess
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: plazomat] #1697377
11/12/14 05:40 AM
11/12/14 05:40 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
A cone unit is better than nothing if you can get it cheap.
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: NTOLERANCE] #1697378
11/12/14 12:13 PM
11/12/14 12:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The cone type survived for 12 years behind the TT440 with manual and automatic transmissions.
It was still locking up and making traction in the end despite the locking screw for the cross pin breaking. When that happened the pin spun in the case and ate the diff. However, the cones were still holding the axles together.
I ended up replacing it with a TrueTrac.
- Stu Harmon
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: feets] #1697379
11/12/14 03:52 PM
11/12/14 03:52 PM
JohnRR Offline
JohnRR  Offline
That happened because the spiders on that shaft had welded them selves to the shaft, it wasn't in as good a shape as you think ... but at least you had fun ...
Re: Should I buy this 8 3/4 sure grip center chunk? [Re: JohnRR] #1697380
11/12/14 07:03 PM
11/12/14 07:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Yep. One was stuck pretty good but the other was free. Still, the cones were working as designed.
- Stu Harmon
