Re: Should I buy this 8 3/4 sure grip center chunk?
[Re: plazomat]
#1697362
11/11/14 12:26 AM
11/11/14 12:26 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I don't see a pic. Does the s/g have clutches?
[Re: plazomat]
#1697364
11/11/14 12:41 AM
11/11/14 12:41 AM
NTOLERANCE
Madison Wi
I would say no
That's a cone type sure grip and while it's not a bad unit it's not rebuild able Well it sorta is. To have to do some machining and it's good to go again. For awhile.
Unless you need the other items id pass. The ratios are poor and one is broken so it makes me question the condition of the s/g.
[Re: NTOLERANCE]
#1697368
11/11/14 12:51 AM
11/11/14 12:51 AM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Can't you buy a new sure grip for $400 or so?
They've been on back order for over a year...don't know why, Doc Diff would know.
[Re: bigblock340power]
#1697372
11/11/14 06:53 PM
11/11/14 06:53 PM
Posts: 22,696 Bitopia
jcc
Bitopia
If its a 2.89, yes, its one of one 18/52 R/P tooth count? Otherwise, No, plenty of other bigger fish in the pond.
[Re: plazomat]
#1697374
11/11/14 09:17 PM
11/11/14 09:17 PM
Posts: 5,163 CT
GTX MATT
CT
Not worth 300, I'd say the SG unit it worth 100. Value the rest at what you want.
[Re: GTX MATT]
#1697375
11/12/14 12:38 AM
11/12/14 12:38 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
the sure grip may be worth $100 but only if it's not junk ... but it's a cone type so it's already JUNK by design.
[Re: feets]
#1697379
11/12/14 03:52 PM
11/12/14 03:52 PM
JohnRR
U.S.S.A.
It was still locking up and making traction in the end despite the locking screw for the cross pin breaking. When that happened the pin spun in the case and ate the diff. However, the cones were still holding the axles together.
That happened because the spiders on that shaft had welded them selves to the shaft, it wasn't in as good a shape as you think ... but at least you had fun ...
