exhaust is so potent it hurts my throat #1696715
11/09/14 11:09 PM
11/09/14 11:09 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
I've noticed the last couple times I've driving the Dart (mild 360), the exhaust is getting really potent - burns the back of my throat when I'm driving .. it's also got a little bit of a stumble off the line, and every now and then if I jump on the gas after sitting at a stop light, it'll give a pop out the carb.. sounds to me like timing? I had it running really good, no stinky exhaust.. but lately I've been noticing it getting worse.
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696716
11/09/14 11:28 PM
11/09/14 11:28 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pull a spark plug, take a pic and post it. i'll bet it's running rich.
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696717
11/09/14 11:31 PM
11/09/14 11:31 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sounds rich.
Check into a wide-band o2 gauge and/or recorder. Step into the 21st century and forget looking at plugs.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: exhaust is so potent it hurts my throat [Re: GoodysGotaCuda] #1696718
11/09/14 11:32 PM
11/09/14 11:32 PM
Sacramento, CA
Sacramento, CA
Sounds rich.
I'd need to put one in each header, right? I've been thinking about this, actually
Re: exhaust is so potent it hurts my throat [Re: mikemee1331] #1696719
11/09/14 11:33 PM
11/09/14 11:33 PM
Sacramento, CA
Sacramento, CA
once the engine cool off, I'm going to pull a plug or two.. but I had it tuned a few months back, and we got the AF ratio dialed in really well and I haven't changed anything in the carb since then (Edelbrock Performer 600 cfm)
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696720
11/09/14 11:44 PM
11/09/14 11:44 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sounds rich.
Ideally, yes.
But one could assume matching jets and idle screws on both banks would get you close on the unmonitored bank. Even that way, you'll be able to fine tune idle, part-throttle cruise, and WOT far more efficiently than reading plugs.
I wouldn't hesitate to buy something like an LM2 duo, or similar, if I was going to be running a carb'd car down the road. Log inductive RPM, each banks A/F and i think engine temp or a couple other parameters could be monitored with that.
Re: exhaust is so potent it hurts my throat [Re: GoodysGotaCuda] #1696721
11/10/14 12:52 AM
11/10/14 12:52 AM
Sacramento, CA
Sacramento, CA
Sounds rich.
Ideally, yes.
zoinks!! Not inexpensive!!!
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696722
11/10/14 12:59 AM
11/10/14 12:59 AM
IN
ahy Offline
ahy  Offline
IN
Per your experience, a mild cammed engine should not be stinky. Good idea to check ignition first. Visual inspection of cap, rotor, distributor and plugs. Check timing also. If the wires are old, replace. It may well be a carb problem, but best eliminate ignition first.
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696723
11/10/14 01:14 AM
11/10/14 01:14 AM
Too rich or too lean could make it gassy. A lean misfire, the cyl is too lean to fire but the unfired (even tho lean) mixture which is still potent enough then goes out the tailpipe & you smell it. Yes an LM1 would be state of the art for tuning but something is deteriorating/going bad unrelated to your current jetting cuz it was running OK before now it ain't. lets find/fix it. I never discount a basic compression/leakdown tests then I'd start with the plugs/plug wires for a possible misfire culprit (& rotor phasing/radial gap may be borderline) & float level/saturated for a rich condition. Holler how it turns out. EDIT reread & saw the hesitation, I'm thinking lean misfire, vac leak maybe
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696724
11/10/14 01:34 AM
11/10/14 01:34 AM
Cab_Burge Online work
Cab_Burge  Online Work
How old is the gas in the car?
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696725
11/10/14 01:46 AM
11/10/14 01:46 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Tool to be used on a car that's how expensive? For how many years?
It'd be an investment, and you can certainly get by with just the tool and a single wideband though. If you forsee messing with carbs for a while, it's not a bad way to go.
Have some friends run O2 bungs in their cars and split the cost, rent it to them, etc. three cars over three years would be $72/car/year to tune with the best thing out there. It doesn't sound so bad that way.. Log at the track, on the road, summer, winter, etc. having that data available is really handy.
I usually find a way to make specialty tools pay for themselves
Re: exhaust is so potent it hurts my throat [Re: Cab_Burge] #1696726
11/10/14 01:47 AM
11/10/14 01:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One thing, dual planes feed two cylinders on each side of the engine. Single planes feed all eight from a common plenum. Monitoring one side will tell you something about both sides of the carb regardless.
Don't be the exception.
Re: exhaust is so potent it hurts my throat [Re: GoodysGotaCuda] #1696727
11/10/14 01:49 AM
11/10/14 01:49 AM
Sacramento, CA
Sacramento, CA
and you also have local friends who are into cars! My best friend drives a Range Rover or his wifes car - an Infiniti G37S.. my other close friend drives a Focus.. LOL
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696728
11/10/14 01:50 AM
11/10/14 01:50 AM
Sacramento, CA
Sacramento, CA
OK.. plugs are a little white ... and .... 'fuzzy'...
And gas is fine.. I fill it up about every other week, I've put 5k miles on it in the last 10 months...
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696729
11/10/14 01:51 AM
11/10/14 01:51 AM
Sacramento, CA
Sacramento, CA
2
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696730
11/10/14 02:09 AM
11/10/14 02:09 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks either a tad rich or the heat range is a step cold.
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696731
11/10/14 03:19 AM
11/10/14 03:19 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Offers have been made to you on several occasions from people not too far from you but you don't seem to want to take them up on it. Your thread regarding the tuning before dyno day was one example. The fuel issues you had could have been fixed within a couple of hours if you would have tapped your local resources. If you continue to ignore the offers, they will surely cease to exist.
Re: exhaust is so potent it hurts my throat [Re: cal_gecko] #1696732
11/10/14 07:17 AM
11/10/14 07:17 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I'm no expert on reading spark plugs but that looks super lean to me! If it were running rich, the plug would be black and sooty.
Re: exhaust is so potent it hurts my throat [Re: cjskotni] #1696733
11/10/14 12:18 PM
11/10/14 12:18 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
anti-freeze/water?
Re: exhaust is so potent it hurts my throat [Re: lewtot184] #1696734
11/10/14 01:27 PM
11/10/14 01:27 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Is the distributor loose by chance and moved?
Ron
