What color is this paint code? #1695156
11/06/14 02:41 PM
11/06/14 02:41 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I would like to know what the color would be for the paint code on this fender tag. The car is painted B5 but I am curious as to what color it should be.
Re: What color is this paint code? [Re: 440mopar] #1695157
11/06/14 02:52 PM
11/06/14 02:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
with the green vinyl top - best guess "rallye green"
Re: What color is this paint code? [Re: 6bblgt] #1695158
11/11/14 08:23 PM
11/11/14 08:23 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
Wouldn't Rallye Green have been F6 on the tag?? A "99" code is for special order paint.
Re: What color is this paint code? [Re: fjr340gts] #1695159
11/11/14 10:55 PM
11/11/14 10:55 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
F6 is F6, Rallye Green is it's own color and one of the special order 99 codes. A couple years ago I looked at a 69 GTX that was painted F8 because they couldn't figure out what 99 meant. Nobody had ever seen a GTX in Rallye Green, so it was definitely a special order, didn't even have the GTX lower trim and no sign it was ever there!
JB Rhinehart, Realist
A-Body's RULE!
Re: What color is this paint code? [Re: Rhinodart] #1695160
11/11/14 11:37 PM
11/11/14 11:37 PM
Alabama
BigMoneyLewis Offline
Alabama
I thought "rallye green" was introduced around March 1969 along with
Bahama Yellow, Vitamin C etc. Mid year "spring" colors .
The car in question has an October SPD
Greg
gregward@mchsi.com phone 256-852-0955
Re: What color is this paint code? [Re: BigMoneyLewis] #1695161
11/12/14 03:32 AM
11/12/14 03:32 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Greg
Greg, what color would you call this? (Yep. Sucks to be color blind. I really can't tell.)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: What color is this paint code? [Re: 69CoronetRT] #1695162
11/12/14 06:01 AM
11/12/14 06:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Discussion of F6 vs Rallye Green vs 1968 Chevrolet-Rallye Green Metallic here:
https://board.moparts.org/ubbthreads/showflat.php?Number=6216267
Re: What color is this paint code? [Re: 69CoronetRT] #1695163
11/12/14 06:14 AM
11/12/14 06:14 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
including the 2 examples shown in this thread I have info from:
7 Plymouth b-bodies (all Road Runners) with "99" special order paint & 925xxx VONs
All are SPD'd between A23 (Wed. 10/23/68) and C03 (Tue. 12/3/68)
All are from the LA plant
No other 925xxx VON Plymouth b-bodies
3 are "rallye green" and 3 are "Omaha orange" (& one is unknown 9E125300?)
What is the significance of the "16" (roof paint) on the OP's tag (shown prior to repaint in this attachment), even though it is a vinyl top car?
RM21H9E116984 was originally "RALLYE GREEN"
The hardtop RR in the upper right is the green interiored RR tag 69CoronetRT attached. It is "rallye green".
Re: What color is this paint code? [Re: 6bblgt] #1695164
11/17/14 12:38 AM
11/17/14 12:38 AM
St.Louis, MO
694406 Offline
694406  Offline
St.Louis, MO
Great thread. Are there differences in the codes at the LA plant? I owned a Rallye green that was a 97 code. I've also seen Omaha Orange codes that were 98.
And I'm still confused about the 16 on the originally posted tag!
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 Cuda 383 4-spd Notch
1969 GTS Black on White 340 4-spd
1971 Cuda 383 V2, X9 Billboards, White Top!
Re: What color is this paint code? [Re: 694406] #1695165
11/17/14 02:01 AM
11/17/14 02:01 AM
Alabama
Alabama
I believe the 16 is 1G =Green vinyl top.
Greg
Re: What color is this paint code? [Re: BigMoneyLewis] #1695166
11/17/14 02:15 AM
11/17/14 02:15 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Greg
..... but "1G" is the gator-grain top. Wrong location for the vinyl top in '69.
WAG - it has something to do with the "ASSUMED" "rallye green metallic" paint in association with the date of this car's build (possible first "rallye green metallic" car or batch?). BW has a few special order paint fleet car's info with "16" "20" and/or other odd 2-digit paint codes. My brother has a '73 Charger with "426" (it looks like JB9) & Nick's FM3 '71 R/T is "148".
