Stage6 heads? #1694989
11/06/14 12:50 AM
11/06/14 12:50 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
Hi guys. can anyone tell me if I can use a tunnel ram with stage 6 heads?
Re: Stage6 heads? [Re: buck440] #1694990
11/06/14 01:22 AM
11/06/14 01:22 AM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
yep.
Re: Stage6 heads? [Re: buck440] #1694991
11/06/14 01:38 AM
11/06/14 01:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Low deck = RB manifold
Re: Stage6 heads? [Re: Viper469] #1694992
11/06/14 02:32 AM
11/06/14 02:32 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
yep.
Nice car! Would you mind sharing your engine specs? My 496 with Stage VI has gone 9.76@135! Thanks Matt
Re: Stage6 heads? [Re: Wicked49670dart] #1694993
11/06/14 02:45 AM
11/06/14 02:45 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
Stage 6 heads on low deck with tunnel ram
Re: Stage6 heads? [Re: Joes66dart] #1694994
11/06/14 12:40 PM
11/06/14 12:40 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Very nice! What does this combo run?
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Stage6 heads? [Re: Wicked49670dart] #1694995
11/06/14 12:54 PM
11/06/14 12:54 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
It should run mid 9's when we get it all sorted out. It's a 470 low deck in a 66 dart chassis car. Weighs 3100 with driver
Re: Stage6 heads? [Re: Viper469] #1694996
11/06/14 01:14 PM
11/06/14 01:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yep.
how do you see the "tree" with all of that?
Coming soon!!!!
Re: Stage6 heads? [Re: buck440] #1694997
11/06/14 01:38 PM
11/06/14 01:38 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If you put them on an RB block you will need spacers to run an RB manifold. Mopar made/makes a specific 4bbl intake to use on an RB block without spacers , I do not know if they make a tunnel ram version .
Re: Stage6 heads? [Re: JohnRR] #1694998
11/06/14 02:08 PM
11/06/14 02:08 PM
dogdays Offline
dogdays  Offline
To complicate the issue, didn't MP have some Stage VI heads in later years that didn't need the spacers? I seem to remember that.
R.
Re: Stage6 heads? [Re: dogdays] #1694999
11/06/14 09:30 PM
11/06/14 09:30 PM
JohnRR Offline
JohnRR  Offline
R.
Yes they did but they were not stage 6's, just the same basic casting ... well they were sort of the same as they didn't fit on the block without some rework too ... they were a replacement type head with stock port location and a 1/2"ish passage for exh crossover.
Re: Stage6 heads? [Re: JohnRR] #1695000
11/06/14 09:57 PM
11/06/14 09:57 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
R.
Yes they did but they were stage 6's ... well they were sort of as they didn't fit on the block without some rework too ... they were a replacement type head with stock port location and a 1/2"ish passage for exh crossover.
All true,heres a pair on my 440
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Stage6 heads? [Re: 6bblFLASH] #1695001
11/06/14 10:13 PM
11/06/14 10:13 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
And that manifold is?
Re: Stage6 heads? [Re: Bill MeLater] #1695002
11/06/14 11:14 PM
11/06/14 11:14 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
DLI modified Offenhauser for a blower
Re: Stage6 heads? [Re: 6bblFLASH] #1695003
11/07/14 01:18 AM
11/07/14 01:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Needed spacer/adapter to use a 440 BDS intake on Chapman heads.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stage6 heads? [Re: hemi-itis] #1695004
11/07/14 10:32 PM
11/07/14 10:32 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
Thanks guys mine are on my 440. they have spacers. The reason I ask is my team g manifold will not bolt up center bolt holes are off?
Re: Stage6 heads? [Re: buck440] #1695005
11/08/14 11:04 AM
11/08/14 11:04 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I would like to try a tunnel ram set up on my 500ci/575 hp crate engine. Just need to start looking for parts.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stage6 heads? [Re: buck440] #1695006
11/08/14 01:08 PM
11/08/14 01:08 PM
JohnRR Offline
JohnRR  Offline
In which direction ?? Is just the manifold off or are the spacers also off ?
Re: Stage6 heads? [Re: JohnRR] #1695007
11/10/14 01:09 AM
11/10/14 01:09 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
Just the manifold. all but the center 4 bolts line up.
