How Much Stall?
#1694936
11/05/14 09:55 PM
11/05/14 09:55 PM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
I have a 408/904 in my Aspen R/T and noticing my 60' times have been slowing down even with new slicks. I run a 8" TCS converter but when I run the play back after a run it shows it on the launch at 5400. When I had this motor on the dyno the torque was 550@4500 rpm. Should I have them tighten it up some on the stall? Brad
Re: How Much Stall?
[Re: 77DragracerR/T]
#1694938
11/05/14 10:14 PM
11/05/14 10:14 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My peak torque is around 5000 rpm, flash at the line is 6500+rpm. Shifts at 7100.That has been the fastest combo so far. I tried a tighter converter along with advancing the cam and the car slowed down two tenths. Not sure if it was cam or converter, But it should show itself come spring.
Re: How Much Stall?
[Re: Cab_Burge]
#1694941
11/06/14 12:48 AM
11/06/14 12:48 AM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
call Lenny at Ultimate Convertor. I replaced my 8'' TCS and switched out to Lenny's 8'' and gained everywhere. ET, MPH, and 60'.
