How Much Stall? #1694936
11/05/14 09:55 PM
11/05/14 09:55 PM
Burlington,Ont.
77DragracerR/T Offline OP
Burlington,Ont.
I have a 408/904 in my Aspen R/T and noticing my 60' times have been slowing down even with new slicks. I run a 8" TCS converter but when I run the play back after a run it shows it on the launch at 5400. When I had this motor on the dyno the torque was 550@4500 rpm. Should I have them tighten it up some on the stall?
Brad
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: How Much Stall? [Re: 77DragracerR/T] #1694937
11/05/14 10:05 PM
11/05/14 10:05 PM
Burlington,Ont.
Burlington,Ont.
Car & driver is #3420 and running 4.57 gears
Re: How Much Stall? [Re: 77DragracerR/T] #1694938
11/05/14 10:14 PM
11/05/14 10:14 PM
gregsdart Offline
gregsdart  Offline
My peak torque is around 5000 rpm, flash at the line is 6500+rpm. Shifts at 7100.That has been the fastest combo so far. I tried a tighter converter along with advancing the cam and the car slowed down two tenths. Not sure if it was cam or converter, But it should show itself come spring.
Re: How Much Stall? [Re: gregsdart] #1694939
11/05/14 11:14 PM
11/05/14 11:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I pick a converter by going 1500 rpm below shift point
Re: How Much Stall? [Re: 77DragracerR/T] #1694940
11/05/14 11:48 PM
11/05/14 11:48 PM
You need to figure out why the car is, what is actually causing the car, (not assume that the converter is ) to slow down first. I've spent a lot of time, effort and money chasing assumed gremlins , don't be that guy Figure out exactly what is going wrong before fixing or replacing something else
Re: How Much Stall? [Re: Cab_Burge] #1694941
11/06/14 12:48 AM
11/06/14 12:48 AM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
call Lenny at Ultimate Convertor. I replaced my 8'' TCS and switched out to Lenny's 8'' and gained everywhere. ET, MPH, and 60'.
