Fast EZ-EFI-1 on a 426 #1694338
11/04/14 01:41 PM
11/04/14 01:41 PM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
Will dual Fast EZ-EFI-1 units (with base adapters) physically fit a stock 426 intake or would you have to go with the "Holley" dual intake?
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Fast EZ-EFI-1 on a 426 [Re: 426runner] #1694339
11/04/14 11:00 PM
11/04/14 11:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call FAST and find out Leet us know, I have drilled AVS, Carter Competion series and Eddy Carbs to fit on 426 Street Hemi intakes You can to probally on those throttle bodies
Re: Fast EZ-EFI-1 on a 426 [Re: Cab_Burge] #1694340
11/05/14 11:08 AM
11/05/14 11:08 AM
Jacksonville, Fl
Jacksonville, Fl
I did... the tech guy had no idea. I've asked for dimensional specs but they claim not to have any. I can't find a website or online picture anywhere with this setup. I guess I'll have to find one and measure it myself.
Re: Fast EZ-EFI-1 on a 426 [Re: 426runner] #1694341
11/05/14 11:42 AM
11/05/14 11:42 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
There is a member on here with another dual quad setup, like mine on a big block, I think it was a wedge, it was a few years ago now.
Theres more room since there are no fuel bowls, like my old holley's
Re: Fast EZ-EFI-1 on a 426 [Re: DJVCuda] #1694342
11/05/14 01:31 PM
11/05/14 01:31 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Yikes: Those don't look like they'll work on a stock Hemi intake. They will fit on the "marine" intake though.
Sheldon
Re: Fast EZ-EFI-1 on a 426 [Re: RUNCHARGER] #1694343
11/05/14 02:00 PM
11/05/14 02:00 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
The holleys I had ( with a metering plate were alot closer.
Re: Fast EZ-EFI-1 on a 426 [Re: DJVCuda] #1694344
11/05/14 02:20 PM
11/05/14 02:20 PM
Montana
DDodger Offline
DDodger  Offline
Montana
interestin
Re: Fast EZ-EFI-1 on a 426 [Re: DJVCuda] #1694345
11/05/14 06:09 PM
11/05/14 06:09 PM
Jacksonville, Fl
Jacksonville, Fl
I know they would fit using the MP intake for use with 2 Hollyes but that tacks on another chunk of $$ I was hoping to avoid. I'm going for it either way. I'll hold off on the intake until I see for myself that they won't fit.
Re: Fast EZ-EFI-1 on a 426 [Re: DJVCuda] #1694346
11/05/14 09:00 PM
11/05/14 09:00 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I have the dual quad setup on a Hemi but it's with a stage v intake
Re: Fast EZ-EFI-1 on a 426 [Re: 426runner] #1694347
11/05/14 11:05 PM
11/05/14 11:05 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Let us know if it works or not please. I'm injecting mine pretty quick as well.
Sheldon
Re: Fast EZ-EFI-1 on a 426 [Re: RUNCHARGER] #1694348
11/06/14 02:04 PM
11/06/14 02:04 PM
dogdays Offline
dogdays  Offline
I look at that large amount of cash and wonder it maybe it'd be better spent going port injection, using the Holley latest stuff (ask Monte Smith).
R.
Re: Fast EZ-EFI-1 on a 426 [Re: dogdays] #1694349
11/06/14 11:46 PM
11/06/14 11:46 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I'd like to Port inject mine but it would be about $5-$6k instead of $3k. The TBI will still be better than carbs I figure.
Sheldon
Re: Fast EZ-EFI-1 on a 426 [Re: RUNCHARGER] #1694350
11/07/14 01:48 AM
11/07/14 01:48 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Sheldon
I had holley 390's on my tunnel ram - I'll try and attach vids of both idling.
You can sit in the seat and adjust the ratio - IN THE SEAT, adjust idle, etc, best move I ever made - runs great in ALL conditions. hot, cold, different altitudes, etc - it adjusts to keep your settings. That alone was worth it. At the track i was always adjusting acc pump cams, jets, idle, etc - not anymore.
Here is the vid from the carbs - notice the heater hose shaking -
VID 1 HERE
here is the vid of the EFI
EZ EFI VID 2
Re: Fast EZ-EFI-1 on a 426 [Re: DJVCuda] #1694351
11/07/14 01:12 PM
11/07/14 01:12 PM
Savage MN
sanman68 Offline
sanman68  Offline
Savage MN
Wow that's why I would like fuel injection on my motor. What a difference/improvement. Only thing is the cost.
Sanman68
Re: Fast EZ-EFI-1 on a 426 [Re: sanman68] #1694352
11/07/14 09:40 PM
11/07/14 09:40 PM
dogdays Offline
dogdays  Offline
The OP was talking about dual EZ-EFIs, which is a bunch of money. Heck, one of those is a lot of money to me.
Holley's controller is multifunctional and I believe will run port EFI for less than the price of two EZ-EFIs. But I could be wrong. On the Race Engine board, check out Monte Smith, he works for Holley and will be the best one to talk to.
R.
Re: Fast EZ-EFI-1 on a 426 [Re: dogdays] #1694353
11/13/14 12:44 PM
11/13/14 12:44 PM
Jacksonville, Fl
Jacksonville, Fl
Dual FAST EFI kit with external fuel pump system can be found for under $2700... complete.
