Fast EZ-EFI-1 on a 426
#1694338
11/04/14 01:41 PM
11/04/14 01:41 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
Will dual Fast EZ-EFI-1 units (with base adapters) physically fit a stock 426 intake or would you have to go with the "Holley" dual intake?
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
Re: Fast EZ-EFI-1 on a 426
[Re: Cab_Burge]
#1694340
11/05/14 11:08 AM
11/05/14 11:08 AM
426runner
Jacksonville, Fl
I did... the tech guy had no idea. I've asked for dimensional specs but they claim not to have any. I can't find a website or online picture anywhere with this setup. I guess I'll have to find one and measure it myself.
Later, Sandy
[Re: DJVCuda]
#1694345
11/05/14 06:09 PM
11/05/14 06:09 PM
426runner
Jacksonville, Fl
I know they would fit using the MP intake for use with 2 Hollyes but that tacks on another chunk of $$ I was hoping to avoid. I'm going for it either way. I'll hold off on the intake until I see for myself that they won't fit.
Later, Sandy
[Re: RUNCHARGER]
#1694350
11/07/14 01:48 AM
11/07/14 01:48 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I'd like to Port inject mine but it would be about $5-$6k instead of $3k. The TBI will still be better than carbs I figure.
Sheldon
I had holley 390's on my tunnel ram - I'll try and attach vids of both idling.
You can sit in the seat and adjust the ratio - IN THE SEAT, adjust idle, etc, best move I ever made - runs great in ALL conditions. hot, cold, different altitudes, etc - it adjusts to keep your settings. That alone was worth it. At the track i was always adjusting acc pump cams, jets, idle, etc - not anymore.
Here is the vid from the carbs - notice the heater hose shaking - VID 1 HERE
here is the vid of the EFI
EZ EFI VID 2
[Re: dogdays]
#1694353
11/13/14 12:44 PM
11/13/14 12:44 PM
426runner
Jacksonville, Fl
Dual FAST EFI kit with external fuel pump system can be found for under $2700... complete.
Later, Sandy
