Re: Factory sometimes left the door jams with primer ?
[Re: cudagee]
#1694086
11/04/14 06:09 AM
11/04/14 06:09 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
I have LA built 1970 EW1 alpine white Challenger R/T 383 that the door jams and front inside parts of the doors have factory gray/green paint, or could it be that at the last minute color was changed. The car was built in October of 1969
In the areas were the hinges are there is a green/grey dip primer. Usually you only see it when you remove/break-away a door hinge or fender (one top of inner fender bolt rail).
[Re: cudagee]
#1694096
11/04/14 05:54 PM
11/04/14 05:54 PM
autoxcuda
So Cal
This car has the original paint...That's why I'm puzzled
During it's life outside the factory, someone painted the jambs.
Maybe they stopped there. Maybe they just intended to stop there. There's 40 years of odd weird out of this world things that can happen to these cars.
[Re: cudagee]
#1694098
11/05/14 04:12 AM
11/05/14 04:12 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Hinges from the same car with original factory primer and paint, looking down on the top side of the hinges.
