Best Intake Manifold? #1694006
11/03/14 09:48 PM
11/03/14 09:48 PM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
OK, I'm sure this topic has been kicked around before but...: What is the best intake manifold for an rb block @ 500 ci with a dominator?
Re: Best Intake Manifold? [Re: Dduster] #1694007
11/03/14 10:18 PM
11/03/14 10:18 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what heads are you using
standerd ports .........M1 4500 or victor 440 intake and 4500 adapter
max wedge ports 440-3 or 440-2 with 4500 adapter
1.39 9.85 - 137 mph
Re: Best Intake Manifold? [Re: Ari440] #1694008
11/03/14 10:30 PM
11/03/14 10:30 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Super Victor is 4500 and offered in standard and Max wedge.
Re: Best Intake Manifold? [Re: Dduster] #1694009
11/03/14 10:33 PM
11/03/14 10:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Low deck here but the Victor/adapter was faster/better then the M-1 for me at that time. Plus of course the "treatment" on the dommy will finish it off.
Re: Best Intake Manifold? [Re: Ari440] #1694010
11/03/14 10:37 PM
11/03/14 10:37 PM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
B1-BS heads. Whose 4500 adapter? Doesn't the manifold come with a dominator stud pattern or is the adapter to optimize airflow distribution? I gotta put on my T-Stop too, don't want an adapter if I can avoid having things stacked too tall for current hoodscoop. Thanks for the input
Re: Best Intake Manifold? [Re: Dduster] #1694011
11/03/14 10:44 PM
11/03/14 10:44 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
The Victor is 4150 only. Need adapter to run a Dominator, or run a super Victor which is 4500, has more plenum volume too.
Re: Best Intake Manifold? [Re: Dduster] #1694012
11/03/14 10:48 PM
11/03/14 10:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
When I use a Dominator on a 4150 manifold, I get 4 aluminum bolts and tighten them in to the bolt holes. The cut them flush and drill and tap the Dominator pattern. Studs are a little safer here, but not required.
Master, again and still
Re: Best Intake Manifold? [Re: DaveRS23] #1694013
11/03/14 10:55 PM
11/03/14 10:55 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
your heads are standerd ports ?
give you an idea how tall it gets
1.39 9.85 - 137 mph
Re: Best Intake Manifold? [Re: GTS340] #1694014
11/03/14 11:12 PM
11/03/14 11:12 PM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
OK,.. adapter makes sense for a 4150 flanged 'Victor' intake manifold. I see 'Super Victor' as the winner with my using a T-Stop. Thanks Guys
Re: Best Intake Manifold? [Re: Dduster] #1694015
11/04/14 01:18 AM
11/04/14 01:18 AM
AndyF Offline
AndyF  Offline
Super Victor is probably the best 4500 intake with std ports but the M1 4500 is also a very good intake. The M1 4500 is shorter than the Super Victor so you'll have more room under the hood. There doesn't seem to be a lot of people who use the M1 4500 but I've found that it makes pretty good power.
Re: Best Intake Manifold? [Re: Dduster] #1694016
11/04/14 01:48 AM
11/04/14 01:48 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I use a mopar 337 intake with a dominator adapter. Very good intake and the built in valley tray is a nice feature. As cast the ports are in between std and MW.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
