What is wrong in this pic..?? #1693922
11/03/14 05:40 PM
11/03/14 05:40 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
I have been re-arranging and loading some pics on my new computer, my old one died and I lost a BUNCH of older pics. I ran across this one from a few years back. There is something wrong in the pic,,,can you see what??? Hint::: Strap rigging.
If you like drag racing, support your local track.
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693923
11/03/14 05:41 PM
11/03/14 05:41 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Can't find the problem,,,??? Maybe a pic will help!!
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693924
11/03/14 05:49 PM
11/03/14 05:49 PM
Kirkland, Washington
Pacnorthcuda Offline
the straps wont clear the brake backing plates.
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693925
11/03/14 06:15 PM
11/03/14 06:15 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
Went to all that work to put the brakes on only to take them all back off so you could get the strap back. The best i can do is try to limit the number of times i make myself have to do things twice.
Re: What is wrong in this pic..?? [Re: Racer33] #1693926
11/03/14 06:32 PM
11/03/14 06:32 PM
Guitar Jones Online laugh2
At that point I'd cut the straps off and buy new ones.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693927
11/03/14 06:35 PM
11/03/14 06:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That strap was never designed to be used like that. Both loops on each end should on the hook and the load supported by the strap looped. You need two straps to lift that load.
Re: What is wrong in this pic..?? [Re: Challenger 1] #1693928
11/03/14 07:33 PM
11/03/14 07:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
way to much negative pinion angle + they were probably setting it off the drive shaft
Re: What is wrong in this pic..?? [Re: Pacnorthcuda] #1693929
11/03/14 07:39 PM
11/03/14 07:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Someone thought they were skinning a fat cat......for a little while lol.
Mopar to the bone!!!
Re: What is wrong in this pic..?? [Re: Guitar Jones] #1693930
11/03/14 09:16 PM
11/03/14 09:16 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
THAT'S what I did!!! That strap/sling had been on that housing during the build/assembly and just seemed to be handy every time I moved it,,,UNTILL,,I got ready to put the rear in the car!!!
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693931
11/03/14 09:18 PM
11/03/14 09:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's how I do things in the garage every day. Do and re-do lol. I love it!
Re: What is wrong in this pic..?? [Re: Challenger 1] #1693932
11/03/14 09:19 PM
11/03/14 09:19 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
OSHA doesn't check on me too often,,,I do understand your point, but that sling will lift WAY more than that rear weighs.
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693933
11/03/14 10:27 PM
11/03/14 10:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You could've left it on and used it to tie the car down .
Re: What is wrong in this pic..?? [Re: justinp61] #1693934
11/03/14 11:11 PM
11/03/14 11:11 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
NEVER thought about that!!!
Re: What is wrong in this pic..?? [Re: CHAPPER] #1693935
11/03/14 11:42 PM
11/03/14 11:42 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Next time tie a Bowline knot on each end and you will have a loop that does not get tight. All you do after that is untie it.
