Driveshaft Length bee vs runner 4spd Dana
#1692702
10/31/14 12:04 AM
10/31/14 12:04 AM
Posts: 1,896 New England
Q5_Ed
New England
Is there any significant difference between the length of driveshafts between these 2 cars (69) Looking at a shaft custom made for a bee and wondering if any issues with slightly longer ds for use in a roadrunner?
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: Driveshaft Length bee vs runner 4spd Dana
[Re: Q5_Ed]
#1692703
10/31/14 08:57 AM
10/31/14 08:57 AM
Posts: 305 Wisconsin
Big D A12
Wisconsin
The Road Runner is a bit shorter, .63 inch (5/8"). Part numbers and lengths:
RR - 2996560 50.39" SB - 2996581 50.96"
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: fastmark]
#1692705
10/31/14 11:29 AM
10/31/14 11:29 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Where do you measure from? Center to Center on the u joints?
yes
[Re: Q5_Ed]
#1692706
10/31/14 11:38 AM
10/31/14 11:38 AM
Posts: 18,157 Mass
DAYCLONA
Mass
A shaft too long (Dodge vs Ply swap)will fit, BUT when the suspension/axle compresses/pinion rotates upward on acceleration during it's travel it can force the yoke to bottom out in the tail shaft of the transmission often resulting in a busted tailshaft...the best way to measure for a shaft is to have the rear axle in place with the tires on the ground, tranny installed, proper driveline angles in place, the vehicle at curb weight (if possible) insert just the yoke in the tranny, pull it back out of the tranny a minimum of 3/4", and measure center to center from the u-joints from the yoke's u joint to the center of the pinions u joint for proper shaft dimensions
Mike
[Re: Q5_Ed]
#1692707
10/31/14 01:10 PM
10/31/14 01:10 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
send me the specs of the shaft , if you don't use it I might be able to use it ...
also , if the price is right for the shaft and it's an HD piece you can always have it shortened ...
[Re: JohnRR]
#1692708
11/01/14 12:00 AM
11/01/14 12:00 AM
Q5_Ed
New England
Yes it HD and I'll have it shortened to spec if necessary it may only be 3/8 long... Thanks all
[Re: Q5_Ed]
#1692709
11/01/14 02:47 AM
11/01/14 02:47 AM
JohnRR
U.S.S.A.
.63 is 5/8 and considering the amount of work you are doing to the car I wouldn't size a driveshaft till it's DONE
