Re: Easiest Way to Unstick Float in Carter AFB (old gas)
[Re: GuruRanger]
#1692172
10/29/14 08:30 PM
10/29/14 08:30 PM
RapidRobert
take out the air cleaner center mounting stud. spray around the carb top/bowl gasket perimeter to clean dirt away. remove pump/fast idle linkage as needed so top is unemcumbered. remove the screws. carefully lift the top as to not rip the gasket. invert top & remove floats/pins/needles (return them to same location) & spray it good (& the seat) with some brake kleen. twirl the needle neoprene tapered tip in between your thumb and forefinger to clean & smooth it. I like to spray the gasket with some light oil and same for the bowl screws as they go into aluminum. Check float level and reassemble (you have not altered float level with this but you need to check it (end of float to gasket surface inverted). be careful not to let the float get hung up as you (carefully) lower the assembly in place (another pair of eyes is good) to watch as you lower it & this lets you have both hands on the bowl. EDIT forgot about removing the rods (return piston/rod assy to same side also)
Re: Easiest Way to Unstick Float in Carter AFB (old gas)???
[Re: GuruRanger]
#1692173
10/29/14 08:36 PM
10/29/14 08:36 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I use the handle of a screwdriver and give it a good couple smacks on the top back where the floats hinge. Usually will get it unstuck pretty quick. That's the cheapest free way. Next move would be to take the top off and spray it down with some spray carb cleaner.
On a side note, I've noticed that old fuel mixed with new seems to spoil at a pretty astonishing rate. I would pump out everything you can and replace with fresh fuel.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: GuruRanger]
#1692175
10/29/14 09:41 PM
10/29/14 09:41 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Shame on you for letting it sit. Now go put some miles on it before the ice man comes.
[Re: GuruRanger]
#1692178
10/30/14 12:08 PM
10/30/14 12:08 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
In my defense, I'm ashamed of how bad the quarter panels look on this otherwise nice car. No one is repopping quarters yet, originals are expensive
I bought a 73 sebring plus at Carlisle back in 93, which my dad owns now... many times we were told they were going to repop them. I don't see it ever happening. Amd does make a nice lower rear section, I think that's all they'll ever make.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: feets]
#1692180
10/30/14 05:03 PM
10/30/14 05:03 PM
Posts: 1,102 Salem, OH (Quaker City Raceway...
GuruRanger
That's the reason my green on green 360 powered RR went away.
Mine was originally Deep Sherwood Poly with white stripes and white bucket interior. That's what I want to restore it back to. Was yours Deep Sherwood, too?
