45 RFE no reverse
#1688988
10/22/14 01:00 PM
10/22/14 01:00 PM
Posts: 410 Chicago
Lee
Chicago
03 Jeep Liberty, no reverse, came back for awile then lost reverse again. No codes. Replaced soleniod pack, found accumulator plate bent and distorted. straightened and replaced missing screws. I also replaced the three seals between the valve body and trans case. No help, still no reverse. What next? I have rebuilt several 727s before but never in a 45 RFE.
Lee
Re: 45 RFE no reverse
[Re: gtx6970]
#1688991
10/23/14 12:04 AM
10/23/14 12:04 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
From what I remember the 45RFE needs no electronics for reverse as its one of the limp mode gears and in reverse all electronics are off as its all mechanical and hydraulic. And it uses the reverse clutch and the low/reverse clutch. I remember some of them breaking the screws in the acumulator plate and leaking fluid internaly past some of the acumulators causing pressure drop in some gears. I would pull the valve body and and air test the reverse clutch as John said. Its a good idea to check codes also. You may have to pull the trans to fix it. Ron
[Re: 383man]
#1688992
10/23/14 11:58 PM
10/23/14 11:58 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
The reverse and low reverse clutches are on in reverse. I would suspect the reverse clutches, fairly typical. Do yourself a favor and install a Transgo Kit which will come with a heavier accumulator plate for the VB, but most importantly will come with a spring and ball to replace the converter limit valve assy in the pump which will be worn out. Also, find a reputable trans shop to install an oversize switch valve plug assy in the VB, major wear there which will eventually kill the OD clutches. Yes, it is coming out.
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: Lee]
#1688996
10/26/14 11:55 PM
10/26/14 11:55 PM
zzyzxpat
Temecula, Ca.
Where is the plug, # 15?
Pat
[Re: Lee]
#1688997
10/26/14 11:57 PM
10/26/14 11:57 PM
zzyzxpat
Temecula, Ca.
A Transgo Kit will give you a new #14 and 15 FYI.
Pat
[Re: zzyzxpat]
#1688998
10/27/14 12:57 AM
10/27/14 12:57 AM
Posts: 410 Chicago
Lee
Chicago
Pat
Thanks for the info, which kit, the 45RFE-HD or the SK-45RFE. Which one do you recommend?
Lee
