CalTracs/Drag Radials and a 4 Speed #1688222
10/20/14 12:58 PM
10/20/14 12:58 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Son took his car out with the new trans and suspension. Not a high power car. Mid to High 12's w/auto. 18 psi, 4200 on Two Step. It starts to plant the tire than it spins. A forward move but turning the tire. It has Calverts 90/10's on the front. Not sure on the rears. If the rears are adjustable do you want more extension? thx matt
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688223
10/20/14 01:20 PM
10/20/14 01:20 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
There is several things to check out... Looser on the extension will help. Make sure the rear shocks aren't topping out on the extension. That will cause the spin. It could also be the front is rising too fast and upsetting the chassis when it tops out. A slow motion camera is invaluable when chassis tuning!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: CalTracs/Drag Radials and a 4 Speed [Re: QTR MILR] #1688224
10/20/14 01:27 PM
10/20/14 01:27 PM
Tucson, Arizona
Tucson, Arizona
I do have video of the pass. Just need to post so it can be linked.
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688225
10/20/14 01:31 PM
10/20/14 01:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you were to call the tire company they would likely not recommend a drag radial for a stick shift car.
68 Barracuda Formula S 340
Re: CalTracs/Drag Radials and a 4 Speed [Re: Bad340fish] #1688226
10/20/14 02:22 PM
10/20/14 02:22 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yeah, Drag Radials & sticks do not go together all that well. Radials like to stay planted & are not forgiving like a slick. You can tune it eventually to get it to some what work.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: CalTracs/Drag Radials and a 4 Speed [Re: 6PKRTSE] #1688227
10/20/14 04:41 PM
10/20/14 04:41 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I just put Cal Tracs on our car. Called their tech line and received information on exactly what you're dealing with. I was told that the shock settings on my 10.90 car were to have the shocks set at number 7 setting. If it does what you're saying...hook, and then spin30-50' out...change the shock setting to number 8. I would highly recommend calling and chatting with their tech folks. They were very friendly and helpful with my setup. Tom
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688228
10/20/14 04:54 PM
10/20/14 04:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Your only hope is full tight on those shocks and then lower rpm till it hooks. What drag radial you go with?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688229
10/20/14 05:09 PM
10/20/14 05:09 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Having run, and still run a stick shift car, I can tell you that radials won't work too well. If the car hooks, then breaks the tires loose, the shocks are extending too fast. You must slow this down by adjusting them to a higher number. When I race, mine are either on 8 or 9. With that being said, don't expect good short times with the radials. Go to a slick or street slick and you'll be much happier with performance.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688230
10/20/14 05:09 PM
10/20/14 05:09 PM
Tucson, Arizona
Tucson, Arizona
He has adjustable shocks and forget about that option. He said they're set on 3 to soften the ride on the street. Brad, They're the MT Street Radial. I'll try to post the video later.
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: 68LAR] #1688231
10/20/14 05:11 PM
10/20/14 05:11 PM
Tucson, Arizona
Tucson, Arizona
He's leaving about 3 tenths on the table with his short times. So the Bias ET Street would work better?
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688232
10/20/14 05:17 PM
10/20/14 05:17 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
[quote He's leaving about 3 tenths on the table with his short times. So the Bias ET Street would work better?
Yep! My son uses them and his car (a real street car), 60's in the low 1'6's to high 1'5's.
Re: CalTracs/Drag Radials and a 4 Speed [Re: 68LAR] #1688233
10/20/14 06:06 PM
10/20/14 06:06 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Tuned my dads barracuda, we use the ET pro, stick shift, SS springs with QA1 SA shocks, Calvert 90/10 fronts. Launched at 6k with a 4.56 gear picked the fronts a little bit, went 1.62 60'
We want to go 1.50's the car isn't optimized and is still in progress but it went 12.22 at 112 so he's a happy old fella
Re: CalTracs/Drag Radials and a 4 Speed [Re: 68LAR] #1688234
10/20/14 06:06 PM
10/20/14 06:06 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I run radials (#1 shock setting) on the street and bias ply (#7 to #9 shock setting) on the track. Cal Tracs in lower position. Still playing with preload and tire pressure and stuff.
The only way to go with a stick car.
Re: CalTracs/Drag Radials and a 4 Speed [Re: LAR_414] #1688235
10/20/14 06:31 PM
10/20/14 06:31 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Go with a stiff sidewall slick if you can.
Made a HUGE difference for me.
Re: CalTracs/Drag Radials and a 4 Speed [Re: sshemi] #1688236
10/20/14 07:26 PM
10/20/14 07:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think a stiff wall slick would work best. If you want a dot approved tire then a bias Mickey Thompson et street or a Hoosier quick time pro. I how ever feel with a good d/a shock and the Mickey Thompson pro radial you could get a stick car to work. I think you will have a really tough time on the old Mickey radial, I think it will be hit or miss at best.
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688237
10/21/14 12:41 AM
10/21/14 12:41 AM
Tucson, Arizona
Tucson, Arizona
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed [Re: 1967dartgt] #1688238
10/21/14 12:54 AM
10/21/14 12:54 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Hit or miss is right. Raced dad's car with both the original radial and the pro in the same weekend, pro was much better
Re: CalTracs/Drag Radials and a 4 Speed [Re: clonestocker] #1688239
10/21/14 12:56 AM
10/21/14 12:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If radials work on a high power trans brake car, why not a stick? The car in question has extension to loose. It slams the housing out, kills the tire and then bounces the rim back off the pavement. A radial requires different valving than a slick. I'd tighten the rear and test again. If that doesn't get it remove hit with the cal track. Still no good? May need a better shock, test and find out.
Doug
Re: CalTracs/Drag Radials and a 4 Speed [Re: dvw] #1688240
10/21/14 01:11 AM
10/21/14 01:11 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
As Badfish340(Clark) said call M/T,Hoosier and they will tell you not to use a DR on a stick car.Sidewall stiffness is the main problem.Transbrake does not hit the tire as hard as M/T car.M/T cars do not like to dead hook.They dead hook and then shake in the 60ft on a high HP car.Multi time DW SB/NA winner has tried for 7 years to get one to hook.Best 60ft has been high 1.40s and best e.t has been 10.20s at 134.Tried every clutch,clutch setting and shock setting out there.Hes finally going with slicks.Driveshaft speed sensor told him all he needed to know. http://www.youtube.com/watch?v=8IgKCwzxJB0
Re: CalTracs/Drag Radials and a 4 Speed [Re: ksj] #1688241
10/21/14 02:26 AM
10/21/14 02:26 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Didn't read through the whole thread, but has he tried just adjusting the 2 step down to about 3k? Obviously there's all kinds of changes you could make to the car to make it stick, but sometimes the most obvious answer can work just fine.
Ultimately, Bias Ply slicks are gonna help a lot, but a small adjustment could make the current combo work.
Damn nice looking Dart by the way.
