CalTracs/Drag Radials and a 4 Speed
#1688222
10/20/14 12:58 PM
10/20/14 12:58 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Son took his car out with the new trans and suspension. Not a high power car. Mid to High 12's w/auto. 18 psi, 4200 on Two Step. It starts to plant the tire than it spins. A forward move but turning the tire. It has Calverts 90/10's on the front. Not sure on the rears. If the rears are adjustable do you want more extension? thx matt
[img] [/img]
Re: CalTracs/Drag Radials and a 4 Speed
[Re: clonestocker]
#1688223
10/20/14 01:20 PM
10/20/14 01:20 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
There is several things to check out... Looser on the extension will help. Make sure the rear shocks aren't topping out on the extension. That will cause the spin. It could also be the front is rising too fast and upsetting the chassis when it tops out. A slow motion camera is invaluable when chassis tuning!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: clonestocker]
#1688225
10/20/14 01:31 PM
10/20/14 01:31 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If you were to call the tire company they would likely not recommend a drag radial for a stick shift car.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1688226
10/20/14 02:22 PM
10/20/14 02:22 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Yeah, Drag Radials & sticks do not go together all that well. Radials like to stay planted & are not forgiving like a slick. You can tune it eventually to get it to some what work.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: clonestocker]
#1688228
10/20/14 04:54 PM
10/20/14 04:54 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Your only hope is full tight on those shocks and then lower rpm till it hooks. What drag radial you go with?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: clonestocker]
#1688229
10/20/14 05:09 PM
10/20/14 05:09 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Having run, and still run a stick shift car, I can tell you that radials won't work too well. If the car hooks, then breaks the tires loose, the shocks are extending too fast. You must slow this down by adjusting them to a higher number. When I race, mine are either on 8 or 9. With that being said, don't expect good short times with the radials. Go to a slick or street slick and you'll be much happier with performance.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: clonestocker]
#1688230
10/20/14 05:09 PM
10/20/14 05:09 PM
clonestocker
Tucson, Arizona
He has adjustable shocks and forget about that option. He said they're set on 3 to soften the ride on the street. Brad, They're the MT Street Radial. I'll try to post the video later.
[img] [/img]
[Re: 68LAR]
#1688231
10/20/14 05:11 PM
10/20/14 05:11 PM
clonestocker
Tucson, Arizona
He's leaving about 3 tenths on the table with his short times. So the Bias ET Street would work better?
[img] [/img]
[Re: sshemi]
#1688236
10/20/14 07:26 PM
10/20/14 07:26 PM
1967dartgt
Hilltown Pa
I think a stiff wall slick would work best. If you want a dot approved tire then a bias Mickey Thompson et street or a Hoosier quick time pro. I how ever feel with a good d/a shock and the Mickey Thompson pro radial you could get a stick car to work. I think you will have a really tough time on the old Mickey radial, I think it will be hit or miss at best.
[Re: 1967dartgt]
#1688238
10/21/14 12:54 AM
10/21/14 12:54 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Hit or miss is right. Raced dad's car with both the original radial and the pro in the same weekend, pro was much better
[Re: ksj]
#1688241
10/21/14 02:26 AM
10/21/14 02:26 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Didn't read through the whole thread, but has he tried just adjusting the 2 step down to about 3k? Obviously there's all kinds of changes you could make to the car to make it stick, but sometimes the most obvious answer can work just fine. Ultimately, Bias Ply slicks are gonna help a lot, but a small adjustment could make the current combo work. Damn nice looking Dart by the way.
