Demon Carb identification help needed #1688209
10/20/14 12:35 PM
10/20/14 12:35 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I got this Demon Carb with a parts lot that I picked up over the weekend.
It doesn't have any identification numbers around the top air horn.
Can anyone guide me on how to identify this carb and how to tell what SCF rating it is?
Any input is appreciated
Re: Demon Carb identification help needed [Re: Finoke] #1688210
10/20/14 12:36 PM
10/20/14 12:36 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Re: Demon Carb identification help needed [Re: Finoke] #1688211
10/20/14 12:50 PM
10/20/14 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks like a speed demon...............
Re: Demon Carb identification help needed [Re: Finoke] #1688212
10/20/14 08:55 PM
10/20/14 08:55 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Most likely it's a Speed Demon 575 or 650. Down leg or annular booster?
Re: Demon Carb identification help needed [Re: Finoke] #1688213
10/20/14 09:37 PM
10/20/14 09:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Measure the throttle bores & do a search.
Re: Demon Carb identification help needed [Re: cruzin] #1688214
10/21/14 12:55 AM
10/21/14 12:55 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I'm not sure what that means. I'm showing my carb ignorance
Re: Demon Carb identification help needed [Re: rickraw] #1688215
10/21/14 12:56 AM
10/21/14 12:56 AM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Will do. So is throttle bore the main influence on the CFM rating?
Re: Demon Carb identification help needed [Re: Finoke] #1688216
10/21/14 03:01 AM
10/21/14 03:01 AM
missouri,usa
cryplydog Online content
cryplydog  Online Content
missouri,usa
do not measure venture dia. measure throttle plate dia.
Re: Demon Carb identification help needed [Re: Finoke] #1688217
10/21/14 12:28 PM
10/21/14 12:28 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
It looks to be a Speed Demon
With the butterflies showing 1.69 I figure that to be 1 11/16".
I have the chart showing 1 11/16" vacuum sec. being either 650 or 750 CFm depending on venturi size.
650 is 1.28 and 750 is 1.40 venturi
Boosters are downleg
650 is .140 750 is .160
I hope this helps.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Demon Carb identification help needed [Re: Hemi Allstate] #1688218
10/21/14 03:59 PM
10/21/14 03:59 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I hope this helps.
Mark
So I found an identification chart on the Internet. A small number 6 is cast on the top of the carb meaning it's a 575 or 650 speed demon.
It's a 575 if the booster is annular. It's 650 if it's down leg. So it sounds like it's a 650.
What does each type of boost Venturi look like?
Re: Demon Carb identification help needed [Re: Finoke] #1688219
10/21/14 04:27 PM
10/21/14 04:27 PM
Mt. Eden Ky.
Mt. Eden Ky.
From what I can see of your above picture yours are down leg.
Annular boosters are larger in diameter, and thicker, and that is why the reduced CFM rating when they are used.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Demon Carb identification help needed [Re: Hemi Allstate] #1688220
10/21/14 04:52 PM
10/21/14 04:52 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Mark
Nice, thx!
Re: Demon Carb identification help needed [Re: Finoke] #1688221
10/21/14 04:57 PM
10/21/14 04:57 PM
Mt. Eden Ky.
Mt. Eden Ky.
One more thing,
I don't show the 575 CFM annular booster as a vacuum secondary carb either.
Mark
1996 Ram 1500 Sport
1968 road runner
