Demon Carb identification help needed
#1688209
10/20/14 12:35 PM
10/20/14 12:35 PM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
I got this Demon Carb with a parts lot that I picked up over the weekend. It doesn't have any identification numbers around the top air horn. Can anyone guide me on how to identify this carb and how to tell what SCF rating it is? Any input is appreciated
Re: Demon Carb identification help needed
[Re: cruzin]
#1688214
10/21/14 12:55 AM
10/21/14 12:55 AM
Finoke
Horsham, Pa.
Down leg or annular booster?
I'm not sure what that means. I'm showing my carb ignorance
[Re: rickraw]
#1688215
10/21/14 12:56 AM
10/21/14 12:56 AM
Finoke
Horsham, Pa.
Measure the throttle bores & do a search.
Will do. So is throttle bore the main influence on the CFM rating?
[Re: Finoke]
#1688217
10/21/14 12:28 PM
10/21/14 12:28 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
It looks to be a Speed Demon With the butterflies showing 1.69 I figure that to be 1 11/16". I have the chart showing 1 11/16" vacuum sec. being either 650 or 750 CFm depending on venturi size. 650 is 1.28 and 750 is 1.40 venturi Boosters are downleg 650 is .140 750 is .160 I hope this helps. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1688218
10/21/14 03:59 PM
10/21/14 03:59 PM
Finoke
Horsham, Pa.
So I found an identification chart on the Internet. A small number 6 is cast on the top of the carb meaning it's a 575 or 650 speed demon.
It's a 575 if the booster is annular. It's 650 if it's down leg. So it sounds like it's a 650.
What does each type of boost Venturi look like?
[Re: Finoke]
#1688219
10/21/14 04:27 PM
10/21/14 04:27 PM
Hemi Allstate
Mt. Eden Ky.
From what I can see of your above picture yours are down leg. Annular boosters are larger in diameter, and thicker, and that is why the reduced CFM rating when they are used. Mark
[Re: Hemi Allstate]
#1688220
10/21/14 04:52 PM
10/21/14 04:52 PM
Finoke
Horsham, Pa.
Mark
Nice, thx!
[Re: Finoke]
#1688221
10/21/14 04:57 PM
10/21/14 04:57 PM
Hemi Allstate
Mt. Eden Ky.
One more thing, I don't show the 575 CFM annular booster as a vacuum secondary carb either. Mark
