A 833 four speed help #1688137
10/20/14 08:55 AM
10/20/14 08:55 AM
indy
70moparmike Offline OP
indy
i took the trans apart thinking all the side cover bolts were the same? found out different, does anyone know where the longer shouldered bolt goes and the two bolts that are threaded and no shoulders? thanks for the help.
Re: A 833 four speed help [Re: 70moparmike] #1688138
10/20/14 11:20 AM
10/20/14 11:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The side cover is thicker where the longer shoulder bolts go. The two threaded bolts go in the holes that the shoulder bolts won't fit into. Pretty logical !!!!!
Re: A 833 four speed help [Re: 70moparmike] #1688139
10/20/14 12:15 PM
10/20/14 12:15 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
.... does anyone know where the longer shouldered bolt goes and the two bolts that are threaded and no shoulders? thanks for the help.
Lower right
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A 833 four speed help [Re: 70moparmike] #1688140
10/20/14 12:50 PM
10/20/14 12:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's pretty easy to figure out , just look ...
There is only one spot on the trans case that has a recessed hole for the longer shoulder bolt ... this bolt locates the cover ... middle in the rear , the 2 long bolts as LAR said , lower right ...
Re: A 833 four speed help [Re: JohnRR] #1688141
10/20/14 02:50 PM
10/20/14 02:50 PM
indy
indy
thanks first time.. not as knowlegable as others. thanks moparts
Re: A 833 four speed help [Re: 70moparmike] #1688142
10/21/14 03:40 AM
10/21/14 03:40 AM
USA
rftroy Offline
rftroy  Offline
USA
John RR has the right answer.
Here is a picture of the rear middle threaded hole on the case. You see that it has a counterbore where the top few threads would normally be. The longer shoulder goes through the cover and into this hole to line up the cover.
Go here for a service manual:
http://www.mymopar.com/index.php?pid=109
I would recommend that you don't try to rebuild the trans without an appropriate service manual. The procedures are slightly different for standard, Hemi box, and OD4 Transmissions.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: A 833 four speed help [Re: rftroy] #1688143
10/21/14 02:44 PM
10/21/14 02:44 PM
Maryland
gofastboater Offline
Maryland
Ditto last post. If you can't figure out where a bolt goes then take to somebody to get redone.
