Harland Sharp rockers and now low oilpressure... #1687800
10/19/14 02:15 PM
10/19/14 02:15 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
Put Harland Sharp roller rockers # S70016K in my Indy EZ 295 head engine.
Now problem is low oil pressure with engine running at idle, normal temp. The gauge shows just 5 Psi of pressure at idle, the oil pressure does go up instantly with Rpm, but I dont like it that its that low at idle... Car is a street/strip car...
I run 5W30 Gulf MAX Supreme oil.
Run a Milodon external oil system, Melling HV pump.
-Am I beeing paranoid about the oil pressure at idle? If not -How can I get a little more oil pressure at idle?
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687801
10/19/14 02:31 PM
10/19/14 02:31 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Their webpage says:
"Oil restrictors may be necessary to maintain oil pressure."
http://www.harlandsharp.com/bb_mopar.htm
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687802
10/19/14 02:32 PM
10/19/14 02:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You can put a Mig welding tip in the rocker stand to help with oil psi.drill the tip to .060 to .100 and cut it to 1/2" and slip it in the rear rocker stand before you put the stud or bolt in and it holds the mig tip in.Done.
Re: Harland Sharp rockers and now low oilpressure... [Re: Clanton] #1687803
10/19/14 02:41 PM
10/19/14 02:41 PM
Stockholm, Sweden
Stockholm, Sweden
Their webpage says:"Oil restrictors may be necessary to maintain oil pressure."
-Yes, Thank You, I also read this. Problem is they dont tell how, what kind, where, etc.. to put the restrictors...
Thanks, this is the kind of info Im looking for?
Any one else have a solution, please post it, if you have pics, post them to...
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687804
10/19/14 02:54 PM
10/19/14 02:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
/Tom
That would be the easiest solution , you need to put something in there to restrict the flow ... but this isn't a stock iron head , Indy's oil differently ...
Nevermind ...
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687805
10/19/14 02:55 PM
10/19/14 02:55 PM
Stockholm, Sweden
Stockholm, Sweden
Looked at the Indy Cylinder Head page.. Found a Head oil restrictor kit # 440-R4-10R.
Any one use this kit? How does it work and how/where do you instal the restrictors? Who sells it?
Also the Indy EZ 295 Heads I have, have the external oil lines, could one put a restrictor in the oil lines going into the heads?
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687806
10/19/14 03:27 PM
10/19/14 03:27 PM
ky
68roadrunner Offline
ky
with my -1 heads and h&s rockers i installed 10-32 brass allen plugs in the fittings going into the heads and drilled to suit myself
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687807
10/19/14 04:05 PM
10/19/14 04:05 PM
I drill and tap(6x32) the NPT end of the fitting that goes into the heads(both sides) and screw a 6x32 brass set screw and drill it to .039 Works good and last along time
Re: Harland Sharp rockers and now low oilpressure... [Re: Cab_Burge] #1687808
10/19/14 04:28 PM
10/19/14 04:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With the Indy-1 and SR head external oil kit if used you can tap the inside of the brass fittings for Holly jets and use .052 to .075 jet sizes to restrict the oil.HS and other rockers that use the needle rollers on the shafts tend to bleed more oil.
Re: Harland Sharp rockers and now low oilpressure... [Re: B G Racing] #1687809
10/19/14 07:14 PM
10/19/14 07:14 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
In my opinion, this is the best, easiest and simplest solution. Been doing it like this for a long time, always works, and is easy to adjust to your liking....
RIP Monte Smith
Re: Harland Sharp rockers and now low oilpressure... [Re: B G Racing] #1687810
10/19/14 08:33 PM
10/19/14 08:33 PM
Stockholm, Sweden
Stockholm, Sweden
Does any one have a pic on how to do this mod? Sounds simple but im kinda a so one or two pics would help alot!
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687811
10/19/14 09:03 PM
10/19/14 09:03 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
This is the only picture I have. I use to make and sell these kits but not any longer. Hope this helps.
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687812
10/20/14 02:15 AM
10/20/14 02:15 AM
So. IL. USA
PLUM BAD Online happy
PLUM BAD  Online Happy
So. IL. USA
Here are pic. of what I did using brass set screws.
Re: Harland Sharp rockers and now low oilpressure... [Re: PLUM BAD] #1687813
10/20/14 02:19 AM
10/20/14 02:19 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Out of curiosity what was the net change in oil pressure?
Re: Harland Sharp rockers and now low oilpressure... [Re: GTX MATT] #1687814
10/20/14 06:19 AM
10/20/14 06:19 AM
Stockholm, Sweden
Stockholm, Sweden
Thank You for the pics!!!
GTX Matt* The oil pressure went down from about 20 psi at idle to 5 psi after the rocker change (engine at running temp). Engine idle is set at 1000rpm.
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: PLUM BAD] #1687815
10/20/14 02:33 PM
10/20/14 02:33 PM
I do mine basically the same as his are I use a #6 brass set screw and install it in the other end (NPT end) of the fittings in the heads so in case it backs out it will be captured in the heads and not on the block sides The ones I buy and use have a small allen head end so I use a .039 drill to open them up all the way through to that size
Re: Harland Sharp rockers and now low oilpressure... [Re: B G Racing] #1687816
10/20/14 06:56 PM
10/20/14 06:56 PM
Stockholm, Sweden
Stockholm, Sweden
This seems the most simple way. If I start to mess with the small brass screws Ill probably just end up and
At idle wouldnt some 10-15 Psi of oil pressure be more than enough???
Thanks again!!!
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #1687817
10/20/14 10:34 PM
10/20/14 10:34 PM
It depends on the idle speed for the prssure, 10 lbs per 1000 RPM works great for me with 5W20 wt oil when it is hot, above 150 F My pump gas 518 C.I. Duster motor idled at 18 to 20 lbs with that oil at or above 160 F oil temps at 850 RPM in gear That was with the Eddy RPM heads, I set the idle RPM higher(1000 to 1100 RPM in gear hot) when I put the Indy heads on it with the external oiling with the .039 restrictors It would have between 25 to 35 Lbs at 1100 RPM or higher, 50 lbs by 2000 RPM with that hot oil
Re: Harland Sharp rockers and now low oilpressure... [Re: PLUM BAD] #2062879
04/27/16 06:41 PM
04/27/16 06:41 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Thanks!
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #2062886
04/27/16 06:49 PM
04/27/16 06:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You need the restricter kit in the oil feed lines - if you run it unrestricted - all your oil will be up in the heads and you risk sucking the pan dry - we use the .060 restricter kitfrom INDY - but like BGR said you can make your own just as easy.
