B engine throttle bracket mod for DP4B intake #1687565
10/19/14 03:40 AM
10/19/14 03:40 AM
NoVa
E
ebodyseast Offline OP
E
NoVa
Need help with Edelbrock DP4B inatake from 1970's for 383 - the stock throttle brackets don't line up with the mounting hole in manifold, what does a finished bracket end up looking like? Did Edelbrock supply throttle brackets that did fit and require no mods to work?
Also - what is the hole in the top of the manifold for, the hole just below the water/nitroous injection threaded port, it leads a channel that flows out the bottom of the manifold. Some DP4B's didn't have this hole/channel cast into them. Thanks men!
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687566
10/19/14 03:54 AM
10/19/14 03:54 AM
NoVa
E
E
NoVa
Here is a link to more pics of hole in manifold top and channels/leading to the bottom
http://www.ebay.com/itm/Edelbrock-vintag...=p2047675.l2557
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687567
10/19/14 09:58 AM
10/19/14 09:58 AM
okla.
O
okie Offline
okie  Offline
O
okla.
My stock brackets worked on mine, they are suppose to be cast like a cast iorn one so shoud;nt be a problem if you have the right brackets
Re: B engine throttle bracket mod for DP4B intake [Re: okie] #1687568
10/19/14 11:57 AM
10/19/14 11:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The intake is a little taller but a stock bracket works, if you need to clearance yours for it to fit that is fine but I don't remember having to do it with my 69 bracket ?
Water water nitrous injection port ???
Don't worry about that hole passage as long as it is not an exh leak.
Re: B engine throttle bracket mod for DP4B intake [Re: JohnRR] #1687569
10/19/14 12:21 PM
10/19/14 12:21 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
back in the day i used the orignal '68 bracket when i went to the dp4b. the later 2 hole brackets may have an issue with the wider runners.
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687570
10/19/14 01:07 PM
10/19/14 01:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I like new good quality parts on my engine like the stuff AndyF sells
http://arengineering.com/home-page/throttle-bracket-kits/
Gus
64 Plymouth Savoy
Dana 60
Re: B engine throttle bracket mod for DP4B intake [Re: lewtot184] #1687571
10/19/14 04:34 PM
10/19/14 04:34 PM
NoVa
E
E
NoVa
Okay great I really appreciate the info. Here is the bracket style being used and has the protrusion at tip (circled) doesn't allow the holes to line up.
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687572
10/19/14 04:37 PM
10/19/14 04:37 PM
NoVa
E
E
NoVa
Here's a similar/different B engine throttle bracket that may be a direct fit for DP4B - since it doesn't have any protrusion cast into this 'style.' What have you all done to the style (above; w/protrusion) to get it to fit?
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687573
10/19/14 04:43 PM
10/19/14 04:43 PM
NoVa
E
E
NoVa
Here are the two 'ports' in question; one under carb leading into plenum is threaded and all DP4B's I've seen have always been plugged.
The other hole below that - I've seen a golf tee plugging it in one guy's...
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687574
10/19/14 07:59 PM
10/19/14 07:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the lower hole connects to the heat crossover and is for a tube that would connect to the hot air choke of the older 3310 holley. with the advent of electric chokes this port isn't needed. the port up by the plenum is just vacuum take-off port. plug it if it's not needed.
Re: B engine throttle bracket mod for DP4B intake [Re: lewtot184] #1687575
10/20/14 01:10 AM
10/20/14 01:10 AM
NoVa
E
E
NoVa
Great to know this bit of info. So the coil was moved to accommodate the 3310 Holleys, too, and the choke ports. Those two hot choke holes will need plugged some way when running other carbs.
Which of the two Mopar B engine throttle brackets pictured above did you men have no install issues with? From the looks they both appear to be too thick at the mounting hole area...
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687576
10/20/14 01:59 AM
10/20/14 01:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
is this a trick question ???
Grind it till it fits.
I do not remember grinding on my bracket , but it might have been like the lower , I'd have to dig thru boxes of parts to figure it out , the car has been apart for about 14yrs .
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687577
10/20/14 02:01 AM
10/20/14 02:01 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
grinder
Re: B engine throttle bracket mod for DP4B intake [Re: forphorty] #1687578
04/04/15 02:56 AM
04/04/15 02:56 AM
NoVa
E
E
NoVa
Glad to update this old thread I started a few months ago. Here is the '70 B engine throttle bracket after grinding off the area (shown above) to clear the DP4B's #7 runner.
Re: B engine throttle bracket mod for DP4B intake [Re: ebodyseast] #1687579
04/04/15 07:29 AM
04/04/15 07:29 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
And then use Fel Pro #1214 Valley Pan with Heat Block Off Crossovers installed in the pan and your good to go
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
