Re: B engine throttle bracket mod for DP4B intake
[Re: okie]
#1687568
10/19/14 11:57 AM
10/19/14 11:57 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
My stock brackets worked on mine, they are suppose to be cast like a cast iorn one so shoud;nt be a problem if you have the right brackets
The intake is a little taller but a stock bracket works, if you need to clearance yours for it to fit that is fine but I don't remember having to do it with my 69 bracket ?
Water water nitrous injection port ???
Don't worry about that hole passage as long as it is not an exh leak. .
[Re: ebodyseast]
#1687576
10/20/14 01:59 AM
10/20/14 01:59 AM
JohnRR
U.S.S.A.
What have you all done to the style (above; w/protrusion) to get it to fit?
is this a trick question ???
Grind it till it fits.
I do not remember grinding on my bracket , but it might have been like the lower , I'd have to dig thru boxes of parts to figure it out , the car has been apart for about 14yrs .
[Re: ebodyseast]
#1687579
04/04/15 07:29 AM
04/04/15 07:29 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
And then use Fel Pro #1214 Valley Pan with Heat Block Off Crossovers installed in the pan and your good to go
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
