w2 questions
#1685998
10/15/14 01:23 AM
10/15/14 01:23 AM
Posts: 137 LI, new york
gmachinedart1
LI, new york
Hi everyone. I recently purchased a used 360/w2 limited circle track engine and have a few general questions.I don't have much info on the engine other that it is a 360 with unported w2 , solid flat tappet, victor intake , stainless roller rockers, roughly 10:1 compression and was being turned to 7200 rpm.I havnt heard it run yet and plan on brining it to the dyno to see if it is healthy or not before I install it in my 70 dart. I think I also plan to run the engine in its current configuration for now as well , with future plans to have heads ported and select a different cam. This is my first w2 engine.
I purchased a new set of TTI headers and noticed TTI is only selling the 1 7/8 headers with a 3.5" collector when they used to offer it in a 3" as well. I will be using the car mainly as a road course track day car. Does anyone think with a full 3" exhaust , the 3.5 collector will hurt torque or is this something I should lose sleep over? I was considering cutting off the 3.5 and use a 3" merge.
I would like to ck the valve lash before I run it ,Can anyone advise on what would be a good starting point ? With my current 360 iron head, HS roller rocker , solid set up I run .016I/.018E.
What would be a good starting point for holley carb size/cfm?
Car is 3300# w/driver , 5 spd ,355 gear.
any suggestions/advice appreciated thank you justin
Re: w2 questions
[Re: gmachinedart1]
#1685999
10/15/14 01:49 AM
10/15/14 01:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
There is 2 different type of W-2 heads.. econo and race.. econo heads have cast in stands for the rocker shafts... the race have a flat milled on them for stands and both heads have long or standard valve lengths available... the W-2 heads arent that good with out porting... as for valve lash is it a roller or FT cam but .018 would work for either with out issue... as for the 3.5 collector... leave them on.. they help.. when I built my W-2 headers they are 1 7/8 pri with 3.5 collectors then I have elec dumps then 3" exhaust to the rear bumper with the muffs just before the bumper ![](/ubbthreads/images/graemlins/wave.gif)
Re: w2 questions
[Re: gmachinedart1]
#1686000
10/15/14 02:02 AM
10/15/14 02:02 AM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Regards valve lash, assuming the engine is complete and as it was ran, I would check the lash on all valves as it sits and make note of them. You will likely find the vast majority are the same, and maybe one or two are off/ have moved. Set those to where the rest all are. That's highly likely where they belong. If the engine isn't complete and together......,the above won't do you any good... Lol
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
Re: w2 questions
[Re: gmachinedart1]
#1686004
10/15/14 02:19 AM
10/15/14 02:19 AM
MR_P_BODY
ok, thanx. They are the race head but not sure if they are a long valve or not off hand. It is a FT cam. I noticed the amount of thread on the adjusters seems excessive. Is it possible this thing was run like this at sustained high rpm without a problem? As far as unported w2 , im just curious how it does on the dyno as is. I was told it made mid 500hp, we'll see.
The adjusters would just say to me that the PRs are a bit short... is it best... no.. it tends to side load the adjusters much harder the farther out they are ![](/ubbthreads/images/graemlins/wave.gif)
Re: w2 questions
[Re: gmachinedart1]
#1686009
10/15/14 02:41 AM
10/15/14 02:41 AM
MR_P_BODY
When I set up the PR length I do a couple of checks first.. I have a tool I made up so I can put a rocker on it and see if the roller tip and the center line of the shaft is in line and where the actual pivot of the PR should be(down in the cup)... they should all be in a line... some might want 1 thread showing and some might want more or less ![](/ubbthreads/images/graemlins/wave.gif)
Re: w2 questions
[Re: pittsburghracer]
#1686013
10/15/14 11:09 AM
10/15/14 11:09 AM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
adjuster
That BLUE pushrod tells a story.
Absolutely, look at the burnt on oil on the pr cup.
Re: w2 questions
[Re: gmachinedart1]
#1686017
10/15/14 10:02 PM
10/15/14 10:02 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
Hey, if you would like a visual reference on a real live running W2 small block, you are welcome to come take a look at my junk. W2/340, MP .557 solid, Victor, TTi step headers.
I'm up in Huntington. PM me if you're interested.
'71 Duster '72 Challenger '17 Ram 1500
