Re: 727 Fluid- What and Why? [Re: KnuckleDuster] #1685840
10/15/14 10:00 PM
10/15/14 10:00 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
For torqueflite 727 and 9XX transmisions, Chrysler changed recommendations as fluid improved.
About 2/3 way down in this 2002 Motor Magazine article they summarize the differences in ATF up to 2002.
Type F has the opposite characteristics than most of the other fluids. Many racers have used it in torqueflites for that reason.
My conclusions that the 'best' claims to backword compatible ATF for a plain 'A' or 'Dexron' spec'd torqueflite are:
Dexron VI (synthetic and generally most expensive)
Synthetic Dexron spec'd as Dex III replacement
Dexron/Mercon (least expensive)
Multi-purpose (usually least expensive, but IMO these are a crap shoot on compatibility)
The newer ATFs usually have better oxidation resistance and low temperature viscosity. Whatever you buy, check the can (uh bottle) or the manufacturer that its compatible with Dex II or earlier.
Warning: Some bottles say compatible with all Chrysler transmissions. This is a bad sign. The needs of all Chrysler transmissions are not the same. Many do not take Dex III and earlier. There are long articles on this (go to Allpar.com for an example). As stated by others, the big change in Chrysler ATF seems to be when ATF+3 and +4 were developed specificly for the new transmissions with control modules.
Another moparts thread on Dexron and Type F characteristics In it, an oil dealer posts some of the viscosity specs for Dex VI, Dex III, and F synthetics in his product line. Note that this specs, especially for Dex III and Type F may not be the same as other brands, but it is a good way to see one way these ATFs are different.
edit corrected link
Re: 727 Fluid- What and Why? [Re: John_Kunkel] #1685841
10/15/14 10:04 PM
10/15/14 10:04 PM
moparx Offline
moparx  Offline
ATF+4 is formulated for transmissions with lockup converters and overdrive gears that run constantly...not features that you find in the majority of performance 727's.
Although Mopar says it is backwards compatible with previous fluids and recommends it for older 727's they do that mostly to be able to stock just one fluid in their service/parts departments rather than 3 or 4.
and just to add more confusion to this topic, i ran dexron in my 95 caravan, which speced the +4 to 308k without a trans failure, and i have almost 200k on my 2000 caravan with a mix of +4 and dexron. still on the original trans. dumb luck or ??????
Re: 727 Fluid- What and Why? [Re: John_Kunkel] #1685842
10/15/14 10:15 PM
10/15/14 10:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
All I can tell you is that many years back I had an old beat up Mopar wagon with a 383, 727. The trans started slipping between gears when it shifted. I was using the old wagon to pull the dirt tract car to the track, and it was racing season, no time to fix the hauler! So like a good boy, I dropped the pan, scrapped all the "stuff" out of the pan, changed the filter and added the Dextron fluid. The slip was still there. My friend that worked on transmissions suggested I try the Ford fluid, so I dropped the pan, replaced the filter again, and filled it up with the Ford fluid. The trans quit slipping, and we got another year out of it pulling the race car before something else went out in the old wagon. Without a doubt, the Ford fluid helps the clutch linings.
I've used Ford fluid in all my non-OD transmissions since. The newer OD stuff gets the ATF+4. Gene
Re: 727 Fluid- What and Why? [Re: poorboy] #1685843
10/15/14 10:44 PM
10/15/14 10:44 PM
North Austin
KnuckleDuster Offline OP
North Austin
Great debate! I have always run Type F, but got a new Turbo Action converter and it listed +4 as the first choice and Type F as the second. I filled the converter with F upon install,but haven't filled the trans yet...thought I'd ask and see what I don't know about ATF.
Re: 727 Fluid- What and Why? [Re: moparx] #1685844
10/16/14 08:40 AM
10/16/14 08:40 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
dumb luck or ??????
I suspect just good luck, not dumb luck. My guess is that Chrysler just decided not to roll the dice on their dime.
The way I read the Motor Magazine article, Chrysler developed the "plus" ATFs at roughly the same time GM was developing Dexron III. There might have been similar modifications to deal with the possible "shudder" issues. Whether for engineering or marketing reasons, or a little of both Chrysler decided to stick with their spec'd ATF.
Re: 727 Fluid- What and Why? [Re: Mattax] #1685845
10/16/14 10:35 AM
10/16/14 10:35 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I had a fellow that did my trans work a while back tell me just use red fluid!!! Just go buy the cheapest red fluid you can find and run it. Did that and never had a problem so
Re: 727 Fluid- What and Why? [Re: max_maniac] #1685846
10/16/14 11:00 PM
10/16/14 11:00 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
I just got my trans done.. Trans guy said to use type f... Convertor I bought tci? said to use red fluid/. I bought the f. Kevin
71 gtx.....
Re: 727 Fluid- What and Why? [Re: sleddinfool] #1685847
10/16/14 11:30 PM
10/16/14 11:30 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Kev...
You'll be OK...
'71 X's like Type F...
Been using it, trouble-free, for 20+ years...
Nice, firm shifts...
Nice, clean trans pan...
