Trans Question on my Liberty
#168412
12/16/08 07:24 AM
12/16/08 07:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
My 06 Liberty has a trans issue. When I am coming to a stop but dont come to a full stop and then accellrate the trans will flare then hit/slame into low. The engine idles a little bit low also(all the time), I've been trying to hold the revs up a little to see if this would correct it(thinking that its just low thottle pressure). Anyway, is the throttle pressure adjustable on this trans and also can the idle be turned up without a hassel. I checked the trans fluid level in N when it was warm...... also forgot to mention that the trans only does this warm. I bought this veh a couple of months back but didnt see this issue before.... I dont think it was there Thanks
Re: Trans Question on my Liberty
[Re: MR_P_BODY]
#168413
12/16/08 11:36 AM
12/16/08 11:36 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Raf..
Talked to Scott
He said that tranny has 3 speed sensors, one of them might be bad...does it turn on the check engine light??
[Re: MR_P_BODY]
#168415
12/16/08 12:22 PM
12/16/08 12:22 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Jeep uses 2 differnet trans in those if it is the 45rfe they had some problems with the seal in the pump where the filter goes in they would leak and you would get air pockets they also had a run of bad cooler line filters also that would cause engagment problems.Both filters are in the pan the other trans is a 42rle it has only 1 filter and I have seen a few with problems with the o-ring on the filter.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#168416
12/16/08 12:53 PM
12/16/08 12:53 PM
MR_P_BODY
Thanks, now I have to determine which trans I have
[Re: dusturbd340W5]
#168417
12/16/08 02:16 PM
12/16/08 02:16 PM
MR_P_BODY
Dusturbd, from what I read, the 42rle has the trans cooler in front of the rad and the 45 does not. Is there anything else that I can see that tells me which trans is which thanks
[Re: MR_P_BODY]
#168418
12/16/08 02:23 PM
12/16/08 02:23 PM
dusturbd340W5
Kissimmee Fl.
the pan on a 45rfe has a kickout on the right front kinda like a 727
[Re: dusturbd340W5]
#168419
12/16/08 03:55 PM
12/16/08 03:55 PM
MR_P_BODY
Thanks for the info... some day I might learn transmissions, he!! I'm just now getting my 727 figured out... LOL
[Re: MR_P_BODY]
#168420
12/16/08 11:48 PM
12/16/08 11:48 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Very simple.... 42RLE is Gas engine 45RFE is Diesel engine There are 2 variants of the 42RLE in `06 depending on which way it was ordered...One with Variable line pressure and one without Quote:
Talked to Scott
Find someone else to talk to...BOTH the RFE and RLE have only TWO (input and output) speed sensors.
Raff...to answer a couple of your questions...NO you can`t change the line pressure, NO you can`t change the idle speed
Has this had the fluid changed lately ?
Rick
[Re: Blown71X]
#168423
12/17/08 11:27 AM
12/17/08 11:27 AM
MR_P_BODY
Very simple....
Talked to Scott
Rick
I dont think so.... I bought this 06 used a couple of months ago but havent driven it much(I was out west with my other ride,wife's truck)I did see that you should use 1 type of fluid only otherwise it could/can have issues. Since you say the idle and trans are a fixed condition(cant be changed) how do I get the idle up a couple hundred revs.. is this all in the computer, if so, do I get it re-flashed and the same with the trans. This is under warrenty but I would prefer to correct it before it really be comes a major problem thanks
[Re: 727jim]
#168429
12/17/08 01:11 PM
12/17/08 01:11 PM
MR_P_BODY
So, I have the non-VLP unit.... is there something that can can be checked to correct this flair condition coming to a stop. If I do come to a complete stop and sit for a moment it will be in low and its fine. I was just thinking it was a line pressure thing but I could/most likely be wrong. Or should I just take it back to the dealer
[Re: MR_P_BODY]
#168430
12/17/08 01:22 PM
12/17/08 01:22 PM
Blown71X
super gas
super gas
A tad North of Indy
Is this thing on ??? Since my opinion dosen`t seem to count, i`ll throw this last thing out.
Raff Since you are unsure of the trans history, a couple of things...Has the battery been dead or disconnected lately? as this will clear the learned CVI values
At a minimum, the first thing you need to do is get somebody to do a Quicklearn on it, this will reset the clutch volume indexes (CVI), if you do, have them record the before and after, On the off chance there is an internal issue this will help in diagnosis As I said before, you can not change the idle speed, it is dictated by the PCM and even if you manage to physically open the throttle blades it will then set a "target idle not reached" DTC
Rick
[Re: Blown71X]
#168431
12/17/08 01:34 PM
12/17/08 01:34 PM
MR_P_BODY
Rick
Rick, no the battery hasnt beedn disconnected or dead. What is the idle speed for these, mineis (on the tack) 475-500 in gear. If I let off of the brakes on a level road at idle it doesnt move forward at all, to me this is a touch to low(idle) which made me think of line pressure on the trans issue. Also what is this Quicklearn thing(no clue here), is this a DRB thing
