Trans Question on my Liberty #168412
12/16/08 07:24 AM
12/16/08 07:24 AM
MR_P_BODY Offline OP
My 06 Liberty has a trans issue. When I am coming
to a stop but dont come to a full stop and then accellrate
the trans will flare then hit/slame into low. The
engine idles a little bit low also(all the time),
I've been trying to hold the revs up a little to
see if this would correct it(thinking that its just
low thottle pressure). Anyway, is the throttle pressure
adjustable on this trans and also can the idle be
turned up without a hassel. I checked the trans
fluid level in N when it was warm...... also forgot
to mention that the trans only does this warm. I
bought this veh a couple of months back but didnt
see this issue before.... I dont think it was there
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168413
12/16/08 11:36 AM
12/16/08 11:36 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Raf..
Talked to Scott
He said that tranny has 3 speed sensors, one of them might be bad...does it turn on the check engine light??
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Trans Question on my Liberty [Re: B3422W5] #168414
12/16/08 12:17 PM
12/16/08 12:17 PM
Don, no it doesnt turn on the light
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168415
12/16/08 12:22 PM
12/16/08 12:22 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Jeep uses 2 differnet trans in those if it is the 45rfe they had some problems with the seal in the pump where the filter goes in they would leak and you would get air pockets they also had a run of bad cooler line filters also that would cause engagment problems.Both filters are in the pan the other trans is a 42rle it has only 1 filter and I have seen a few with problems with the o-ring on the filter.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Trans Question on my Liberty [Re: dusturbd340W5] #168416
12/16/08 12:53 PM
12/16/08 12:53 PM
Thanks, now I have to determine which trans I have
Re: Trans Question on my Liberty [Re: dusturbd340W5] #168417
12/16/08 02:16 PM
12/16/08 02:16 PM
Dusturbd, from what I read, the 42rle has the trans
cooler in front of the rad and the 45 does not. Is
there anything else that I can see that tells me
which trans is which
thanks
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168418
12/16/08 02:23 PM
12/16/08 02:23 PM
Kissimmee Fl.
Kissimmee Fl.
the pan on a 45rfe has a kickout on the right front kinda like a 727
Re: Trans Question on my Liberty [Re: dusturbd340W5] #168419
12/16/08 03:55 PM
12/16/08 03:55 PM
Thanks for the info... some day I might learn transmissions,
he!! I'm just now getting my 727 figured out... LOL
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168420
12/16/08 11:48 PM
12/16/08 11:48 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Very simple....
42RLE is Gas engine
45RFE is Diesel engine
There are 2 variants of the 42RLE in `06 depending on which way it was ordered...One with Variable line pressure and one without
Talked to Scott
Find someone else to talk to...BOTH the RFE and RLE have only TWO (input and output) speed sensors.
Raff...to answer a couple of your questions...NO you can`t change the line pressure, NO you can`t change the idle speed
Has this had the fluid changed lately ?
Rick
Re: Trans Question on my Liberty [Re: Blown71X] #168421
12/17/08 10:03 AM
12/17/08 10:03 AM
Kissimmee Fl.
Kissimmee Fl.
Very simple....
42RLE is Gas engine
Talked to Scott
Rick
I guess they made some changes I have a 45rfe here on the floor that came out of a 02 Lierty with a 3.7l v6 gas motor
Re: Trans Question on my Liberty [Re: dusturbd340W5] #168422
12/17/08 10:12 AM
12/17/08 10:12 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
If we were talking about a `02 that would be fine......we aren`t, this is about a `06
RFE was the only auto available on a `02 KJ
On a `06 it is the way I posted.
Rick
Re: Trans Question on my Liberty [Re: Blown71X] #168423
12/17/08 11:27 AM
12/17/08 11:27 AM
Very simple....
42RLE is Gas engine
Talked to Scott
Rick
I dont think so.... I bought this 06 used a couple
of months ago but havent driven it much(I was out
west with my other ride,wife's truck)I did see that
you should use 1 type of fluid only otherwise it
could/can have issues. Since you say the idle and
trans are a fixed condition(cant be changed) how
do I get the idle up a couple hundred revs.. is this
all in the computer, if so, do I get it re-flashed
and the same with the trans. This is under warrenty
but I would prefer to correct it before it really
be comes a major problem
thanks
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168424
12/17/08 11:56 AM
12/17/08 11:56 AM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
Mike here is some info
For the 2006 model year there will be two versions of the 42RLE transmission. The new
variant (variable line pressure - VLP) of the 42RLE transmission, has a new case, valve
body and a variable force style solenoid (pressure control solenoid). The solenoid is duty
cycle controlled by the TCM to vent the unnecessary line pressure supplied by the oil
pump back to the sump. The system also contains a line pressure sensor, the line
pressure sensor is a direct input to the TCM. The line pressure solenoid regulates the
transmission line pressure and completes the feedback loop to the TCM. The TCM
determines desired line pressure based on current gear and engine torque to satisfy road
load conditions (similar to the 545RFE transmission).
2006 vehicles could be built with either variant. The new transmission can be identified by
the sales code of DGV or the new variable line pressure harness connect
how many miles are on this vehicle also give me the vin And i can telkl you which unit is in you vehicle
chat at ya later Ryan and Jim
Re: Trans Question on my Liberty [Re: 727jim] #168425
12/17/08 11:59 AM
12/17/08 11:59 AM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
get me the last 8 vin digits or all if you like
Re: Trans Question on my Liberty [Re: 727jim] #168426
12/17/08 12:32 PM
12/17/08 12:32 PM
Here ya go Jim..... Thanks
6W180936
Re: Trans Question on my Liberty [Re: Blown71X] #168427
12/17/08 12:40 PM
12/17/08 12:40 PM
Kissimmee Fl.
Kissimmee Fl.
Rick
Rick I am not arguring with you like I said I guese they made changes.
Re: Trans Question on my Liberty [Re: 727jim] #168428
12/17/08 12:40 PM
12/17/08 12:40 PM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
here is what you have
DGBS All 4-Speed Automatic Transmissions
DG6 4-Spd. Automatic 42RLE Transmission
DHAP Lock-Up Torque Converter
sales code build
*B5 -D5 DG6 EKG NAA PB8 RSA 28X 4VL
non vlp system
Re: Trans Question on my Liberty [Re: 727jim] #168429
12/17/08 01:11 PM
12/17/08 01:11 PM
So, I have the non-VLP unit.... is there something
that can can be checked to correct this flair condition
coming to a stop. If I do come to a complete stop
and sit for a moment it will be in low and its fine.
I was just thinking it was a line pressure thing
but I could/most likely be wrong. Or should I just
take it back to the dealer
Re: Trans Question on my Liberty [Re: MR_P_BODY] #168430
12/17/08 01:22 PM
12/17/08 01:22 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Is this thing on ???
Since my opinion dosen`t seem to count, i`ll throw this last thing out.
Raff
Since you are unsure of the trans history, a couple of things...Has the battery been dead or disconnected lately? as this will clear the learned CVI values
At a minimum, the first thing you need to do is get somebody to do a Quicklearn on it, this will reset the clutch volume indexes (CVI), if you do, have them record the before and after, On the off chance there is an internal issue this will help in diagnosis
As I said before, you can not change the idle speed, it is dictated by the PCM and even if you manage to physically open the throttle blades it will then set a "target idle not reached" DTC
Rick
Re: Trans Question on my Liberty [Re: Blown71X] #168431
12/17/08 01:34 PM
12/17/08 01:34 PM
Raff
Rick
Rick, no the battery hasnt beedn disconnected or
dead. What is the idle speed for these, mineis
(on the tack) 475-500 in gear. If I let off of the
brakes on a level road at idle it doesnt move forward
at all, to me this is a touch to low(idle) which
made me think of line pressure on the trans issue.
Also what is this Quicklearn thing(no clue here),
is this a DRB thing
