Re: 1974 charger no headlights
[Re: moparvinson]
#1683660
10/09/14 01:42 AM
10/09/14 01:42 AM
RapidRobert
(Headlight) Power flows from the HL switch to the dimmer switch/to bulkhead/out to headlights & start with the dimmer switch, which is either on the floor or in the dash. It has (3) terminals: the power in, power out to the low beams and power out to the high beams which lights up the low beam filaments at the same time. www.mymopar.com will have the colors for you. See if you have fire at the (2) bulkhead terminals (1 for low beams/1 for high/low together) & since you have neither I'd say start at the dimmer switch & if it has power in then work downstream (2 "out" dimmer switch terminals to bulkhead). EDIT I ain't familiar with a headlight relay & how it operates
[Re: Mr_fixit]
#1683663
10/09/14 11:44 AM
10/09/14 11:44 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
If the bulbs are out check for power and ground at the bulb plugs.If not there go to the bulkhead connector.then to the dimmer and finally the switch.Id say dimmer is either bad or not hooked up.Do you have a service manual?If not get one.Rocky
Chrysler Firepower
[Re: Paul_Fancsali]
#1683665
10/10/14 02:22 PM
10/10/14 02:22 PM
Posts: 174 Creedmoor, NC, USA
74Charger
Creedmoor, NC, USA
Check and see if ground wire is on tight out by radiator support bet its the problem. This is wire generally attached to the battery ground ire connection on rad support
Seen this as the problem more than once!
