Re: School me on Original Keys 1965 to 1972
[Re: Rick_Ehrenberg]
#1683393
10/09/14 03:26 AM
10/09/14 03:26 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The Pentastar-shaped head was not introduced until 1970 -- to fit the column-mounted lock cyl.
Rick
Correct, 69 uses the rectangle head, same at 68 and earlier, but Mopar changed vendors for 69 (Yale I believe) and the long milled slot is in a different location than previous and all the teeth are different heights so the lock pins do not interchange.
[Re: 6bblgt]
#1683397
10/09/14 06:23 AM
10/09/14 06:23 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
I have original keys with "A", "B", "I", & "Y" stamped on them, I do not know who the manufacturer or which ones were factory supplied with each year. B = Briggs & Stratton, I = Ilco, Y = Yale
[Re: 6bblgt]
#1683398
10/09/14 10:48 AM
10/09/14 10:48 AM
Posts: 2,151 Bristol, CT
RalphsRapidTrnst
Bristol, CT
Thank you to all What about 1965 and 1966? are the same as 1967?
[Re: Daty Rogers]
#1683400
10/10/14 01:41 AM
10/10/14 01:41 AM
Posts: 81 Alberta
NEVjr
Alberta
Got a 67 BCuda with a pentagon head, round trunk, been that way for years. Must have been something done way back in the day.
-Daty
same for my dads 67 barracuda, originally an arizona car, he got it in the mid 80s, we always assumed they were original.
my 62 valiant (canadian model, not a plymouth) came to me with pentastar head with a B under the star and 770U in the top part for the doors, and a pentastar with a B for the ignition, and a round one with marks worn off for the trunk.
it also has a set of pentastar knock offs with curtis on the star. the door keys hve a different set of grooves than the ignition
the car was delivered in april of 1962, so i guess the keys arent original, if wikis sept 1962 adoption of the pentastar logo is right
[Re: Powerflow]
#1683402
10/12/14 03:39 PM
10/12/14 03:39 PM
Posts: 314 North East Missouri
express
North East Missouri
Here is pic of the Ilco catalog. 1966 was a separate year for the trunk key. The newer key will work though as it has a wider groove.
Ign is 1764P & Trunk is 1766S
1959 -1964 were a side bar lock & there were grooves on only one side of the blank.
Go to a locksmith, don't screw around with the hardware store or the big box store.
