What 26” radiator in 1971 Duster with 6.1 Gen III Hemi #1681883
10/04/14 01:45 PM
10/04/14 01:45 PM
Saint Peters, MO
Brian Offline OP
Brian  Offline OP
Saint Peters, MO
I’m now in the process of building a restified 1971 Duster that will be powered by a warmed over 6.1 Gen III Hemi. I would like to know what off the shelf 26” radiator would fit after the core support is opened up. Ideally I would like to stick with a copper radiator as the look I’m going for is how the factory would have dropped an A-Body on a 6.1 on the assembly line. The car will look like a stock Duster 340 (Rally instrument cluster, sharktooth grill) with the hood closed.
The car will have A/C, manual transmission, P/S manual 4-wheel disc brakes (Mopar 11.75” with Viper calipers) running 225/60 performance tires on 16” steelies. The chassis is being stiffened with the US CarTool chassis stiffening kit. Final mockup now in progress with a 5.7 block, Lakewood bell housing and 833 bolted in place with the TTI motor mounts on a 1971 biscuit K-member.
I’m looking forward to your input.
1971 6.1 Gen III Hemi Duster
26 inch Radiator [Re: Brian] #1681884
10/04/14 05:58 PM
10/04/14 05:58 PM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
Depending on your hose locations, I put a 4 core from a 1974 1-ton dually that is 26 inches into my 1971 Demon. With a little modification to the core support it bolted in using stock mounting bolts and locations. Stock fan shroud fits in as well.
Re: 26 inch Radiator [Re: kenny b] #1681885
10/04/14 07:27 PM
10/04/14 07:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Ur picture shows a flex-fan..
I would dump that @ the earliest possible time. A buddy used a flexfan and a blade broke off cut his upper hose and cut into the radiator. A flexfan may be acceptable for a low rpm street application but not in a high performance engine that revs past 5K rpm..
Just my $0.02...
Re: 26 inch Radiator [Re: Sinitro] #1681886
10/09/14 06:46 PM
10/09/14 06:46 PM
Port Saint Lucie, FL
ChallengerGary Offline
Champion makes one for the swap. It is part number CC1643. It is a 3-row unit that is I sell them for $209 + $25 shipping within the USA.
Click on the link below to see the specs
http://www.championcooling.com/Catalog%20Online/CHAMPION.CATALOG.htm
Re: 26 inch Radiator [Re: ChallengerGary] #1681887
10/09/14 10:05 PM
10/09/14 10:05 PM
IN
ahy Offline
ahy  Offline
IN
One option would be a Mancini "Muscle Car" radiator. It is top tank aluminum and made (quickly) to your specs provided on a form. I run a 26" version on an E with 496 and AC and it cools great. I just had to re-order after a full truck tread on the road took the old one out.
Specs in on Monday, shipped today. They can put the water connections wherever you want them. My "old" one was in place for ~10 years with no cooling deterioration. A coat of radiator paint helps it blend in somewhat.
http://chucker54.stores.yahoo.net/manciniracing27.html
Re: 26 inch Radiator [Re: ahy] #1681888
10/10/14 06:00 PM
10/10/14 06:00 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
If you can get the oulets both on the PS, that will help tons.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
