Re: 93' 5.9 Magnum: Intermittent voltage at coil
[Re: jerseybud]
#1681787
10/05/14 08:08 AM
10/05/14 08:08 AM
Posts: 4,867 Upstate, NY
MikeP
Upstate, NY
http://www.allpar.com/fix/codes/sensors/auto-shutdown.htmlIs this the relay next to the Fuel pump relay attached to the inside fender in the drivers side? I had an issue with the fuel pump getting low amps and "solved" it by splicing in a new ground at the pump to the frame. During the trouble shoot, I unplugged both of these relays looking for corrosion, cleaned the terminals, cleaned the body grounds. I'll replace it and go from there. IF that doesn't solve it, can I run a seperate 12v source to the coil? (12v with key on) Thanks !
[Re: MikeP]
#1681788
10/05/14 09:36 AM
10/05/14 09:36 AM
Posts: 1,019 Finland
mafo
Finland
IF there is a problem somewhere in the wiring the computer may shut down that part I found out the hard way( as usual) when I wired the VSS on my Dodge -55 that use a Jeep/ Van/ Dakota combo of parts, I lost power to the coil and distributor , when I got the VSS wired the right way the other problems magically disappeared
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
