Dodge Monaco C Body Wheel width? #1680873
10/02/14 12:08 AM
10/02/14 12:08 AM
Maine
1965Monaco Offline OP
Maine
I have a newly acquired '65 Monaco and would like to put on some wider, steel wheels with dog dish caps.
Can someone let me know the widest wheel/tire combo for a '65 C-body?
thanks
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680874
10/02/14 12:45 AM
10/02/14 12:45 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have 275/60/15's on the back of my 66 C on an 8" rim with 4" BS.
Ideally I would go with 4.5" BS.
235/70/15 on the front on stock C-body road wheels which are 6" AFAIK.
Kevin
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680875
10/02/14 12:46 AM
10/02/14 12:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Don't know how wide you can go, but be aware the '65 "dog dish" hub caps are 10" VS. '68 & newer being 9-1/2" in diameter.
Re: Dodge Monaco C Body Wheel width? [Re: 6bblgt] #1680876
10/02/14 08:36 AM
10/02/14 08:36 AM
Maine
Maine
Awesome, thank you!
Re: Dodge Monaco C Body Wheel width? *DELETED* [Re: 1965Monaco] #1680877
10/02/14 08:39 AM
10/02/14 08:39 AM
Maine
Maine
Post deleted by 1965Monaco
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680878
10/02/14 08:43 AM
10/02/14 08:43 AM
Maine
Maine
Twostick, do you have the rear lifted at all?
I'd like to lift mine up just a bit so it sits just a little higher than the front. Any suggestion for how much to do, and how?
I assume just longer shackles??
thanks again!
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680879
10/02/14 11:01 AM
10/02/14 11:01 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
No lift, stock springs.
ESPO will sell you new springs with 1 or 2 inches more arch. A spring shop might be able to re-arch yours but I've heard steel has a "memory" and the spring will slowly but surely settle back to where it was.
http://www.springsnthings.com/
To properly re-arch would require heat treatment to re-program the spring if you will.
Kevin
Re: Dodge Monaco C Body Wheel width? [Re: Twostick] #1680880
10/02/14 11:13 PM
10/02/14 11:13 PM
Maine
Maine
Ok, I'll check it out. Thanks!
