Re: pulling dist. drive gear
[Re: fourgearsavoy]
#1680820
10/01/14 11:02 PM
10/01/14 11:02 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I've also used a screwdriver to walk it above the cam gear and then a 90* pick to lift it up further and out.
Careful, your character's showing!
[Re: mopar346]
#1680821
10/02/14 12:33 AM
10/02/14 12:33 AM
RapidRobert
Make a hangmans' noose out of real thin wire, thin like parts tag wire & drop it down & hook it under the gear then get the gear loose & starting to come up with (2) L pics or heavier coat hangar wire with an L bend in the end(s) then with it free hold it up a hair with the parts tag wire & remove the (2) L wires & pull it up thru the tight opening the rest of the way with the parts tag wire
[Re: crlush]
#1680824
10/02/14 01:41 PM
10/02/14 01:41 PM
Posts: 5,163 CT
GTX MATT
CT
Turn it with a screw driver first to drive it over the cam, then take a pair of regular pliers, open them up to the wider setting (handles closer together), stick one half in the drive slot and the other on the outside. Squeeze and pull. Works like a charm.
[Re: 4spdana]
#1680826
10/02/14 03:35 PM
10/02/14 03:35 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Turn the crank backwards.
[Re: ewolfe]
#1680831
10/03/14 11:55 AM
10/03/14 11:55 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Screwdriver to turn above the cam then I use a big ass magnet. This is super easy and works most every time.
thats how i do it.
[Re: AndyF]
#1680833
10/03/14 09:46 PM
10/03/14 09:46 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I have some long reach pliers that will reach the gear. My pair came from SnapOn but you might be able to find similiar pliers from Sears or other tool vendor.
