Wiper cam bushing #1680726
10/01/14 03:49 PM
10/01/14 03:49 PM
sw mo
meanmothermagnum Offline OP
sw mo
Help!!! I just bought a 78 Chrysler lebaron and there is or was a large plastic can type of bushing that went on the motor and the wiper linkage sat down in it. Mine came apart in about half a dozen pieces and now wala no wipers. I have tried the dealer but its an obsolete part. I have also tried dorman parts and none of them are right either. Where could I get such a part? Thank you.
Re: Wiper cam bushing [Re: meanmothermagnum] #1680727
10/01/14 04:29 PM
10/01/14 04:29 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I do not know if those are being reproduced any more. I have come across them, supposedly new, but rather pricey.
If its similar to the F body pieces you could swap over the cam arm and first section of linkage from one without that. There is a difference in the shaft on the motor though so you'll have to do some modifications to the mounting hole in the cam arm. A little filing should work.
Not the clearest picture, but...cam with large bushing on left, non-bushed on right.
Re: Wiper cam bushing [Re: meanmothermagnum] #1680728
10/01/14 04:57 PM
10/01/14 04:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
go to the magnum forum. a guy over there is/was making them. a bit pricey, but if you need one, you need one.
Re: Wiper cam bushing [Re: nomore65BelvJim] #1680729
10/01/14 05:13 PM
10/01/14 05:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I got a new repro bushing kit for my 79 R-body from Van's when I was at Carlisle but it isn't on the website.
$75 IIRC
http://www.vansauto.com/
Kevin
Re: Wiper cam bushing [Re: Twostick] #1680730
10/01/14 06:22 PM
10/01/14 06:22 PM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
if you post a pic of what to look for, I likely have it. mike 816-799-8844
Re: Wiper cam bushing [Re: Golden-Arm] #1680731
10/01/14 06:22 PM
10/01/14 06:22 PM
sw mo
sw mo
I don't see a magnum forum. Do you have a link?
Re: Wiper cam bushing [Re: Golden-Arm] #1680732
10/01/14 08:45 PM
10/01/14 08:45 PM
I seem to remember that the F and M body part arent the same as the other bodies.
Also thought it was a 78 only part. Maybe just for the F and M
Re: Wiper cam bushing [Re: nomore65BelvJim] #1680733
10/01/14 10:31 PM
10/01/14 10:31 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
IIRC it's for intermittent wipers only if it is like the one for my R-body.
Kevin
Re: Wiper cam bushing [Re: Twostick] #1680734
10/01/14 11:03 PM
10/01/14 11:03 PM
Right Kevin, intermittent only, but I think the F/M part and the R and J part are not the same. Unless I'm having another pre-senior moment
Re: Wiper cam bushing [Re: nomore65BelvJim] #1680735
10/01/14 11:48 PM
10/01/14 11:48 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Yes I think that's right. /B/J/R bodies with hidden wipers have the large plastic cam, F/M bodies with exposed wipers have another type.
Someone is reproducing the BJR type now, but I don't think it will work correctly in '78 lebaron?
http://www.ebay.com/itm/1980-1981-1982-1...79a&vxp=mtr
Re: Wiper cam bushing [Re: 440newport] #1680736
10/02/14 12:33 AM
10/02/14 12:33 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That looks like the one I got from Van's.
As far as part#'s go, the arms may be different but the cam/bushing should be the same. The OEM part was sold as an arm and bushing assembly
Kevin
