Re: Wiper cam bushing
[Re: Golden-Arm]
#1680732
10/01/14 08:45 PM
10/01/14 08:45 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
go to the magnum forum. a guy over there is/was making them. a bit pricey, but if you need one, you need one.
I seem to remember that the F and M body part arent the same as the other bodies. Also thought it was a 78 only part. Maybe just for the F and M
[Re: 440newport]
#1680736
10/02/14 12:33 AM
10/02/14 12:33 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Right Kevin, intermittent only, but I think the F/M part and the R and J part are not the same. Unless I'm having another pre-senior moment
Yes I think that's right. /B/J/R bodies with hidden wipers have the large plastic cam, F/M bodies with exposed wipers have another type.
Someone is reproducing the BJR type now, but I don't think it will work correctly in '78 lebaron? http://www.ebay.com/itm/1980-1981-1982-1...79a&vxp=mtr
That looks like the one I got from Van's.
As far as part#'s go, the arms may be different but the cam/bushing should be the same. The OEM part was sold as an arm and bushing assembly
Kevin
