storing a car on biasply tires #1680287
09/30/14 02:06 PM
09/30/14 02:06 PM
Moncton, New Brunswick
hemidart1 Offline OP
If my car sits unmoved for about 5 months-will it ruin the tires if they are bias ply?
I guess I could move it a few inches back and forth but not sure if that will have any affect.
1967 Hemi GTX
1969 Chrysler 300
Re: storing a car on biasply tires [Re: hemidart1] #1680288
09/30/14 02:10 PM
09/30/14 02:10 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I parked mine last October and haven't looked at it since. I was wondering the same thing. Maybe I need to get the tires off the ground this winter.
Re: storing a car on biasply tires [Re: burdar] #1680289
09/30/14 02:48 PM
09/30/14 02:48 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Don't know that it will "ruin" them, but the first time you drive it next year you will definitely have to deal with the "thump*thump*thump*thump" for a while going down the road until the flat spots work themselves out. DAMHIK
Probably not a bad idea to put it up on jackstands/blocks, but I don't have as much data to back it up as some of these other guys do...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: storing a car on biasply tires [Re: hemidart1] #1680290
09/30/14 02:56 PM
09/30/14 02:56 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Shouldnt ruin them but they will likely have flat-spots. Another one of the joys of bias ply tires.
I'd put it up with the tires off the ground.
Re: storing a car on biasply tires [Re: nomore65BelvJim] #1680291
09/30/14 02:58 PM
09/30/14 02:58 PM
where would you place the jack stands?
1967 Hemi GTX
1969 Chrysler 300
Re: storing a car on biasply tires [Re: hemidart1] #1680292
09/30/14 03:11 PM
09/30/14 03:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Under the rear axle spring perches and under the front A arms. that way it puts the weight in the normal places.
Re: storing a car on biasply tires [Re: stumpy] #1680293
09/30/14 03:28 PM
09/30/14 03:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Racer dudes tend to put stands under the frame to allow the springs to decompress. That's less important in a street car, but a thought.
Re: storing a car on biasply tires [Re: stumpy] #1680294
09/30/14 03:53 PM
09/30/14 03:53 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Agreed, keep weight on the suspension.
Re: storing a car on biasply tires [Re: moparjim79] #1680295
10/01/14 12:02 AM
10/01/14 12:02 AM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Re: storing a car on biasply tires [Re: dmoore] #1680296
10/01/14 12:07 AM
10/01/14 12:07 AM
dmoore Offline
dmoore  Offline
Use these on two vehicles the last two years with no flat spot issues....extremely simple alternative that works!
Re: storing a car on biasply tires [Re: dmoore] #1680297
10/01/14 12:12 AM
10/01/14 12:12 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Nothin a couple smoky burnout scant fix
Re: storing a car on biasply tires [Re: sogtx] #1680298
10/01/14 12:17 AM
10/01/14 12:17 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
the obvious solution to the problem. spin the rubber to true them round again.
Re: storing a car on biasply tires [Re: hemidart1] #1680299
10/01/14 01:39 PM
10/01/14 01:39 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Consider engine and exhaust system damage starting engine to move the car a few inches,,,,you should always do a through warm up when starting an engine that is to be not started again for any extended period. Especially in cold weather.
Re: storing a car on biasply tires [Re: hemidart1] #1680300
10/01/14 01:53 PM
10/01/14 01:53 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Flat spots are NOT a function of the tire being biasply, it has to do with what it is made of. Tires with nylon will flat spot, and most of the polyglas tires shouldn't.
Re: storing a car on biasply tires [Re: Sxrxrnr] #1680301
10/01/14 03:56 PM
10/01/14 03:56 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I just put mine in neutral to roll it throughout the winter months...no need to start it.
Re: storing a car on biasply tires [Re: sogtx] #1680302
10/01/14 04:15 PM
10/01/14 04:15 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Agreed that will HEAT them up and round them off
MLR426
