replacing ammeter with a volt meter? #1680019
09/29/14 08:16 PM
09/29/14 08:16 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
i am looking to upgrade the alternator on my 62 valiant, and i would like to make the ammeter into a volt meter.
i am an electrician by trade and i understand the theory of both types of meters, and i know how to do the conversion on a portable analog ammeter, but i am baffled by the spare ammeter i have in front of me, it seems to have no coil, and the shunt is the aluminium gauge face?
i would like to keep the original gauge, is there a conversion kit or anything available?
thanks
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680020
09/29/14 09:34 PM
09/29/14 09:34 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Amp to volts Try this, see if it helps.
Re: replacing ammeter with a volt meter? [Re: Cudajon] #1680021
09/29/14 11:38 PM
09/29/14 11:38 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
that is a pretty good solution if you ask me
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680022
09/30/14 01:38 AM
09/30/14 01:38 AM
IN
ahy Offline
ahy  Offline
IN
Two basic approaches I know of. 1) Pull the guts of an aftermarket voltmeter and install in your cluster 2) Have gauge shop do it (and silkscreen the volt markings).
Both can work... I did the latter and it works great. MA had an article on the DIY method... maybe check back issues.
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680023
09/30/14 04:32 AM
09/30/14 04:32 AM
Does all the amps from the alternator go through the amp gauge like it does on the later Mopar cars? If so that needs to be addressed to safely get the current back to the battery, correct? I recently added a 100 amp alternator to my race car that didn't have a charging system on it when I got it so I used a 8 gauge wire ran directly from the alternator output to the positive post on one of the batterys so the car would not run when the battery cut off switch was turned off. I ran a 18 guage,I think, through the main ignition switch to the voltmeter so I can see if the alternator is working or not when the engine is running. I had a old race car that a guy bought and added a voltmeter in series to the battery in the trunk with no cut off switch or activation switch, it would run the battery dead in a couple of days, it wasn't digital. All electrical gauges use current to run them, correct
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680024
09/30/14 07:48 AM
09/30/14 07:48 AM
Australia
dodgy Offline
dodgy  Offline
Australia
like others I changed my system to volt meter, moded the dash and fitted a volt meter, got the local sticker mob to make me up an overlay.
have a few left but I'd say they would be different to your dash.
Re: replacing ammeter with a volt meter? [Re: Cab_Burge] #1680025
09/30/14 09:54 AM
09/30/14 09:54 AM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
it does go through the ammeter in the dash on #10 wire like later cars
my dash is orange needles over brushed aluminium with black markings
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680026
09/30/14 02:06 PM
09/30/14 02:06 PM
You have two choices, splice or replace those leads If your going to keep a stock Mopar low amp alternator splicing with solder may be a good choice If your going to hop up the alternator(80+ amps or or more) maybe replacing the stock wires for bigger wires ran direct to the battery may be a better choice Good luck either way
Re: replacing ammeter with a volt meter? [Re: Cab_Burge] #1680027
09/30/14 08:16 PM
09/30/14 08:16 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
i have some nice big #4 welder cable to go direct to the battery, i want to pick up a better alternator, maybe 80 or 100A, the stock one wont run all the accessories at once according to the ammeter, (heater fan, headlights, wipers)
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680028
09/30/14 08:47 PM
09/30/14 08:47 PM
I used a 10 ft. piece of #8 wire on my race car with the 100 amp alternator. There is not a huge load on the charging system when racing it, maybe 35 amps total On the splicing I should have mentioned splicng the two wires behind the amp meter in the former post, replacing it is a better deal with anything over 45 amps load I might consider a # 6 if it is from the front of the car to a battery in the trunk, if the run is less than 10 ft I would probally go with #8 or #10 . I think Powermaster, Tuff Stuff or one of the other aftermarket alternator companys has a chart with lemgth, load and wire gauge sizes recommended for there bigger alternators
Re: replacing ammeter with a volt meter? [Re: NEVjr] #1680029
09/30/14 08:56 PM
09/30/14 08:56 PM
IN
ahy Offline
ahy  Offline
IN
In general, the later mid/late 70's square back is a lot stronger than an early 60's round back and will bolt right in. The factory rated them up to 78 amps. You could get a reman at the parts store but I wouldn't recommend it as quality is not good on the ancient cores. I'd go with a Powermaster usually rated 75 amps.
The late style square back will make 50 amps or a bit better idle output. Plenty with near stock accessories. If your future includes electric fan, big electric pump or massive sound system not enough.
The later alternator with two voltage regulator terminals will work with the 60's style single wire regulator. Just hook the original regulator wire to one terminal and ground the other with a jumper. Doesn't matter which is which.
Good luck!
Re: replacing ammeter with a volt meter? [Re: ahy] #1680030
09/30/14 09:30 PM
09/30/14 09:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You realize the battery is only a part time load on the alternator, once it's charged back up it is no longer a load. The rest of the system is the load, so running big wires to the battery doesn't fix the issue just masks it as the ammeter does not measure output from the alternator to the rest of the system, just to/from the battery.
If you truly have large electrical loads you should run them via relays directly sourced from the alternator output.
Don't be the exception.
Re: replacing ammeter with a volt meter? [Re: Supercuda] #1680031
10/01/14 09:16 PM
10/01/14 09:16 PM
Alberta
N
NEVjr Offline OP
NEVjr  Offline OP
N
Alberta
i dont plan to use the #4 because of load, i plan to use it because its around, and i dont have any big loads planned, just basics like maybe a fan and fuel pump, third brake light and the controller for a gear vendors unit. EFI is in the cards as well, and i dont want to worry about putting the car in neutral at every stop light on a rainy night to keep the alternator charging
sound system is going to be a 10w bluetooth amp and speaker set up hidden in the dash behind the original speaker grille, so i can hear my music over the road noise, i can buy a modern car if i want modern distractions
Re: replacing ammeter with a volt meter? [Re: Supercuda] #1680032
10/02/14 04:41 AM
10/02/14 04:41 AM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
I'm assuming something like what is like the wiring diagrams on the Mad Electrical website? Where the alt feeds the fuse box directly and the regulator is sensing volts at the fuse box? Supposedly more stable voltage throughout the system.
The info i'm looking at is on www.madelectrical.com and its towards the bottom of their tech page " bypassing amp gauge".
If anyone has tried these mods chime in please.
Re: replacing ammeter with a volt meter? [Re: dodgy] #1680033
10/02/14 05:23 PM
10/02/14 05:23 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I do all my Amp to volt changeovers like that Harbor Freight sells a small diameter one that I put in 72-80 Dodge trucks
