Carb Fire ? #1679965
09/29/14 04:14 PM
09/29/14 04:14 PM
michigan
440whiteboy Offline OP
michigan
My carb is shooting flames when starting?
The last two days it will flame up.
How normal is this?
Car has been sitting for a couple weeks.
She has an electric fuel pump - I have it set at 4.5 lbs. Floats are set just under the top hole when pushing on fender after pulling screws.
Using 93 octane.
I would turn on key to activate the electric pump for about 2 seconds - would push the gas peddle just a little bit.
I had other cars with same 440 motor - 750df/dp holly set up without this happening.
They only see Stars...
when hit by a Mopar!
Re: Carb Fire ? [Re: 440whiteboy] #1679966
09/29/14 04:19 PM
09/29/14 04:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Check your choke opperation/adjustment, and check your timing and ignition system.
Re: Carb Fire ? [Re: ScottSmith_Harms] #1679967
10/02/14 10:32 PM
10/02/14 10:32 PM
michigan
michigan
ok - thanks Scott -
will have a friend stop by with a timing light.
The carb choke plate is open full - my cable is not attached to it.
Re: Carb Fire ? [Re: 440whiteboy] #1679968
10/02/14 11:26 PM
10/02/14 11:26 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
2 things if you aren't aware.
First I generally would not energize the pump before starting just stroke the peddle once or twice depending on what the car like and fire it up then flip the pump on. You had said it had been sitting so if I did energize the pump it would only be for a second or so (you can actually hear the pump bog down in most cases) and then shut it off til running and flip it back on.
Second if you ever do get a flame out of the carb make sure the pump is off and spin the engine, if will actual such the fire down inside the engine where it will do no damage and burn out once it has spent the fuel you added - don't stroke the throttle it will squirt more fuel into the flame. Literally.
Good luck.
Careful, your character's showing!
Re: Carb Fire ? [Re: 440whiteboy] #1679969
10/02/14 11:41 PM
10/02/14 11:41 PM
iowa
jtgts Offline
jtgts  Offline
iowa
id check timing sounds like its off
does it start at all
Re: Carb Fire ? [Re: 440whiteboy] #1679970
10/03/14 12:29 PM
10/03/14 12:29 PM
Alberta
rustbuckett68 Offline
Alberta
" Floats are set just under the top hole when pushing on fender after pulling screws."
Have they changed Holleys in the last 30 years since I ran mine?
Just asking.
