Cure for floppy rear view mirror? #1677354
09/26/14 09:22 PM
09/26/14 09:22 PM
East Tennessee
Burkenator Offline OP
East Tennessee
The mirror in my Challenger keeps moving around under while driving. Is there any way to tighten it up? It is the ball that attaches to the at the top to the headliner that is loose. Any help would be appreciated. Thanks.
Burke
Re: Cure for floppy rear view mirror? [Re: Burkenator] #1677355
09/26/14 09:25 PM
09/26/14 09:25 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
If its like a b body there should be three screws in the mounting to tighten up a little. not sure on a body
Re: Cure for floppy rear view mirror? [Re: Burkenator] #1677356
09/26/14 09:26 PM
09/26/14 09:26 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I shimmed mine with a piece of soda can, worked well. You may need to beat it thinner.
-Daty
Re: Cure for floppy rear view mirror? [Re: pattyboy 572] #1677357
09/26/14 09:29 PM
09/26/14 09:29 PM
Central TX
roe Offline
roe  Offline
Central TX
Same. You can tighten it down. And if that doesn't work you can take the little piece out and bend it to tighten up the clearances.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Cure for floppy rear view mirror? [Re: Burkenator] #1677358
09/27/14 11:48 AM
09/27/14 11:48 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
If it is loose at the top where the stem meets the base, you will need to remove the mirror and base from the car. When you get it off, you will see a plate that puts pressure on the ball.
You should be able to tighten the screws in order to put enough pressure on the ball to hold the mirror. If not, as mentioned above, you can either bend the pressure plate a bit, or shim it with something.
Master, again and still
Re: Cure for floppy rear view mirror? [Re: DaveRS23] #1677359
09/27/14 04:49 PM
09/27/14 04:49 PM
BDW Offline
BDW  Offline
Answer here, hammer and a couple of raps
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
