Re: Converted to BBP front disks- now have major toe out...
[Re: 72demon416]
#1677324
09/26/14 09:18 PM
09/26/14 09:18 PM
RapidRobert
Nothing is jumping out at me from your descrip. Something is going on & unless those are the wrong lower ball joints I would thread the tie rods in to shorten that assy.
[Re: 72demon416]
#1677326
09/26/14 09:34 PM
09/26/14 09:34 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
When changing from drums to disc The disc set up move the wheels out About 1 1/4" (I think is the amount)
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: draginmopars]
#1677327
09/26/14 10:06 PM
09/26/14 10:06 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
You may have nailed it! - and now that you mention it I remember reading the wheel track is wider now which would absolutely create my condition. The upper control arms have changed to tubulars now but they are labeled left and right so I'm good there. Well...now to see if there if there is enough adjustment in there with my current parts... I don't recall anybody saying the tie rods or drag link were different so I should be ok. Thanks for the ideas guys!
[Re: skicker]
#1677329
09/29/14 12:23 PM
09/29/14 12:23 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
Something there still sounds hinky...the LBJ would be the same drum to disc. IE the outer tie rod attachment would also be the same. Track width has nothing to do with it. Is it possible the LBJ's are on the wrong sides?
^^^ This the track width is dictated by the design of the rotors and spindles, and I wouldn't expect the tie rods to fall in the same place when switching to a newer design spindle and the lower ball joint.
