Kickdown adjustment #1677264
09/26/14 03:14 PM
09/26/14 03:14 PM
Logansport, Indiana
Budman Offline OP
Budman  Offline OP
Logansport, Indiana
71 Scamp 318
Just bought this car. There is no passing gear or downshift with heavy acceleration. The kick down linkage was hooked up to pull the lever on the side of the trans to be pulled forward under acceleration. isn't that backwards? I used a tie-strap and held the lever at trans to the rear and still will not kick down under heavy acceleration.
All MOPARS & nothig else.
Re: Kickdown adjustment [Re: Budman] #1677265
09/26/14 03:31 PM
09/26/14 03:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes that is backwards. You need to install and adjust the linkage correctly. then see what you have going on. Tying it back won't give you kickdown It will just raise the shift points.
Re: Kickdown adjustment [Re: Budman] #1677266
09/26/14 03:35 PM
09/26/14 03:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the lever held to the rear I'm surprised it upshifts.
Re: Kickdown adjustment [Re: John_Kunkel] #1677267
09/26/14 03:40 PM
09/26/14 03:40 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Did the 71s even have part throttle kick down?
I have mechanical Aptitude.
I can screw up anything.
Re: Kickdown adjustment [Re: bboogieart] #1677268
09/27/14 06:19 AM
09/27/14 06:19 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Re: Kickdown adjustment [Re: bboogieart] #1677269
09/27/14 05:41 PM
09/27/14 05:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most did but not all.
