Re: Aluminum head upgrade question
[Re: Clanton]
#1676260
09/23/14 09:18 PM
09/23/14 09:18 PM
McCandless did an back to back deal just like that when the Eddys came out--was over 50 HP gain IIRC may have been a little more simple answer to simple question- something you do not get on this forum very often-- -McCandlessboy is memeber here and if you can contact him I am sure they still have the data but call Marsh Perf and get a set of Sidewinders for way less than Eddys and do exactly the same result if not a little better and save enough to buy a nice carb.
[Re: gold1950]
#1676265
09/24/14 12:38 PM
09/24/14 12:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry, one more question.
If I choose to go with either of these aluminum heads, I assume I can use my existing push rods but what recommendation would you suggest for the valve train since I'm currently using the stock rocker assembly.
I would really doubt you can use the existing PR specially if you change cams... the base of the cam is cut in farther when the lift is increase... I dont know if the rocker shaft mounts are on the same height as stock heads but if they are different then that would make for different PR lengths
[Re: AndyF]
#1676267
09/24/14 02:26 PM
09/24/14 02:26 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Good info here. I am in a similar boat. Looking to upgrade the ported -516's heads on my 493 to something a bit lighter and better flowing.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: MR_P_BODY]
#1676269
09/25/14 12:35 PM
09/25/14 12:35 PM
Posts: 46 Alabama
gold1950
Alabama
Thanks for the reply. I'm not changing the cam (still using the Mopar 509). I'm considering to change from the stock 906 head to an aluminum head like the Edelbrock Performer.
Questions: 1.) If I just change out the heads, what is the suggested rocker assembly to go with ?
2.) Since the Edelbrock heads claim to be bolt-on, does that mean that I can use my existing PR as long as I don't change my cam ?
--> By the way....aren't all heads "bolt-on" ?
I understand your point about the height of the heads determining the length of your PR, guess I need to call Edelbrock to see if they are different.
[Re: gold1950]
#1676271
09/25/14 01:01 PM
09/25/14 01:01 PM
MR_P_BODY
Thanks for the reply. I'm not changing the cam (still using the Mopar 509). I'm considering to change from the stock 906 head to an aluminum head like the Edelbrock Performer. Questions: 1.) If I just change out the heads, what is the suggested rocker assembly to go with ? 2.) Since the Edelbrock heads claim to be bolt-on, does that mean that I can use my existing PR as long as I don't change my cam ? --> By the way....aren't all heads "bolt-on" ? I understand your point about the height of the heads determining the length of your PR, guess I need to call Edelbrock to see if they are different.
What is the engine used for street street/strip.. but a lot of guys like Harlan Sharp rockers but you might be able to get away with a bit less... but my opinion on rockers and valve train parts is to buy good ones the first time so you arent replacing them later.. also I was thinking you were gonna change cams to the 528 like Andy said... if the shafts are on the same height as the stock head then with the adjustable rockers you should be ok... if things werent cut (like the heads)... also.. like was said.. the parts on most of the heads and the valve job arent the best.. I touch up the valve job on ANY new head that comes assembled EDIT and no... not all heads are bolt on... some need massive work
[Re: gold1950]
#1676274
09/26/14 01:23 PM
09/26/14 01:23 PM
Thumperdart
State of confusion
Although I have a low deck stroker(470 ci.), going from ported 906`s to "Thumper" ported rpm`s took me from 10.40`s to 9.79 (so far) but I also went from a solid to a roller. Point is they will work well w/a valve touch up and some light bowl work and clean up in your case. Just did a 2 circuit carb conversion for a friends 470 BB Ferd and ported/converted his E-brock clover leaf manifold into a nice generous standard open plenum and SHOULD take him from his 10.08 best into the 9`s no problem then he`s gonna let me work over his E-brock for even more power. I like the challenge of using a stock replacement head and going faster that some "high dollar" stuff.................fun, fun fun.
