Odd Cuda rear valance?
#1676186
09/23/14 05:30 PM
09/23/14 05:30 PM
Posts: 2,270 St.Louis, MO
694406
St.Louis, MO
I've had this piece in my rafters for years. It's a Cuda but with round cut outs. Can anyone shed some light on this? Thanks!
www.Musclemagnet.com1969 Cuda 383 Q5 1969 Cuda 340 4-spd Notch 1969 Cuda 383 4-spd Notch 1969 GTS Black on White 340 4-spd 1971 Cuda 383 V2, X9 Billboards, White Top!
Re: Odd Cuda rear valance?
[Re: autoxcuda]
#1676188
09/23/14 05:44 PM
09/23/14 05:44 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Dual exhaust car without tip. Turn downs.
For mandatory noise reduction cars in California (440-6, Hemi, other?). Maybe other areas required that too? Also a 383 N code 70/71 Barracuda would get that too. No tip options on those cars I believe.
Maybe 340 72-74 Barracuda (non 'Cuda) got turn downs too? Not familiar with those cars.
I have that on my 74.
Original single exhaust car I believe.
Also AAR cuda's had those rear valances. Not really all that odd.
Jason
[Re: CUDAJAS]
#1676190
09/23/14 06:08 PM
09/23/14 06:08 PM
694406
St.Louis, MO
Jason
AARs had solid valances with no cutouts.
[Re: autoxcuda]
#1676191
09/23/14 06:50 PM
09/23/14 06:50 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Depth of the cutouts seem to be different on repros?
Do the cutouts look more shallow installed on a car?
I'd say more than the depth is different. The entire profile of the bottom edge seems to be way off.
[Re: mopar346]
#1676193
09/23/14 07:52 PM
09/23/14 07:52 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Jason
My original had slight cut outs and from what I have researched that was normal. Batalson sold me an NOS one that he said to be correct for the AAR and it has the same slight cut outs. I'll see if I can find a picture from back int he day.
That's what's confusing. Why have slight dual cutouts and then deep dual cutouts?
It would seem to make more sense to have just one passenger side small cutout for single exhaust. Unless it was just done for visual balance. But one side would have a tail pipe and the other side not.
[Re: autoxcuda]
#1676194
09/23/14 08:00 PM
09/23/14 08:00 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
70/1 N code cars can have the tips along with 340 cars but not on Calf. cars.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: mopar346]
#1676196
09/23/14 08:42 PM
09/23/14 08:42 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
You can see them here if you look close. It actually had regular duals on it in the 80s.
Careful, your character's showing!
[Re: 694406]
#1676198
09/23/14 09:15 PM
09/23/14 09:15 PM
Posts: 2,315 South, FL
cudaized
South, FL
That is a 1970 version of the non Chrome Exhaust tip rear valance. The lower edge gives it away in pictures. Holding it in your hand gives it away. It is heavier then the 71-74 version.
If you turn if over and look at the rear side. You will not see the two vertical braces, as are found in 71-74 and the reproduction version.
[Re: autoxcuda]
#1676199
09/23/14 09:19 PM
09/23/14 09:19 PM
cudaized
South, FL
The BS23 models got the N41 and the N42 Chrome Exhaust Tips, even in CA. The exception were the hemi and 440-6 cars. The noise package only applied to the R and V codes sold and registered new in CA.
[Re: cudaized]
#1676200
09/23/14 09:25 PM
09/23/14 09:25 PM
Posts: 8,852 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
My 70 383 2bbl barracuda has that valance. It didnt come with chrome tips and is a single exhaust car
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: cudaized]
#1676202
09/23/14 10:31 PM
09/23/14 10:31 PM
autoxcuda
So Cal
Ok. So U code single 4 bbl cars did not have to have noise reduction (no tips)?
Read in another thread U code was also no tips.
[Re: cudaized]
#1676203
09/23/14 10:33 PM
09/23/14 10:33 PM
694406
St.Louis, MO
70 vs 71 Non-N42 Chrome Exhaust Tips rear valances.
The depth looks deeper in the 1970 valance. However, it is the same height. Reference the recess area for the lower mounting screw hole. The top of the round exhaust cutout are the same height. Take a look at the bottom of the 71 valance. The bottom has been modified (by the factory) for the 71-74 models. Apparently, in 1970, there was something about the rear leaf springs hitting/bending the bottom of the 1970 valance. So the factory modified it. Kind of like the hemi fenders...make it work.
Awesome info and thanks!
[Re: 694406]
#1676204
09/23/14 10:42 PM
09/23/14 10:42 PM
autoxcuda
So Cal
Thank you. I never knew there were two different valences.
I see AAR's with shallow ones, but are those just replacements?
[Re: autoxcuda]
#1676205
09/23/14 10:48 PM
09/23/14 10:48 PM
cudaized
South, FL
No Sir. They were not required to. Did it happen? Possibly.
