Fuel Sending Unit #1676140
09/23/14 02:09 PM
09/23/14 02:09 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
Any one have a good source for a fuel sending unit for a 1976 Trailduster, they don't seem to exist?
Or have a parts book from back then that would have the correct part number in it. I have located some but just part numbers, don't know what they fit
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Fuel Sending Unit [Re: Mopar_Mudder] #1676141
09/23/14 02:44 PM
09/23/14 02:44 PM
SE PA
Yellow Fever Offline
SE PA
This is the cheapest I've found for a chrysler part:
http://www.tascaparts.com/oe-mopar/4240277
Re: Fuel Sending Unit [Re: Yellow Fever] #1676142
09/23/14 05:14 PM
09/23/14 05:14 PM
Wisconsin
Wisconsin
I will have to pull mine out and see if it looks the same I guess. Or do you know for sure that it the correct part?
Re: Fuel Sending Unit *DELETED* [Re: Mopar_Mudder] #1676143
09/23/14 07:10 PM
09/23/14 07:10 PM
SE PA
SE PA
Post deleted by Yellow Fever
Re: Fuel Sending Unit [Re: Yellow Fever] #1676144
09/23/14 07:12 PM
09/23/14 07:12 PM
SE PA
SE PA
"NOS MoPar fuel tank sending unit. Package PN is 4240277 which includes the complete sending unit, gasket, and filter. Fits all 76-80 models with mid-mounted plastic fuel tank. This tank was situated along with the frame rail under the bed (driver's side). Usually 18-20 gallon. The sending unit mounts from the top, hangs down vertically.
Also listed as a replacement for # 4049131"
Re: Fuel Sending Unit [Re: Yellow Fever] #1676145
09/23/14 07:57 PM
09/23/14 07:57 PM
Wisconsin
Wisconsin
That is where I am not sure if it is the same. They are talking about the tanks on the trucks that are along the frame. The Trailduster / Ramchargers had a plastic tank mounted in the rear between the frame rails.
Re: Fuel Sending Unit [Re: Mopar_Mudder] #1676146
09/23/14 08:51 PM
09/23/14 08:51 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Can it be other than MOPAR? Rock Auto? Summit has one for 40 and change
Re: Fuel Sending Unit [Re: Scott Carl] #1676147
09/24/14 11:28 AM
09/24/14 11:28 AM
Wisconsin
Wisconsin
I guess I don't care as long as it reads correct and works with the stock gauge.
Re: Fuel Sending Unit [Re: Mopar_Mudder] #1676148
09/25/14 02:49 PM
09/25/14 02:49 PM
Earth
Rob C Offline
Rob C  Offline
Earth
I hate to hijack, but, I also can not seem to find this for my 1979 Dodge Magnum. At least the outside of that sender looks to be the same as mine. Any help?
Thanks.
Re: Fuel Sending Unit [Re: Rob C] #1676149
09/25/14 03:16 PM
09/25/14 03:16 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
Thanks.
A-hem.
YOu're getting a PM.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Fuel Sending Unit [Re: Rob C] #1676150
09/27/14 04:30 AM
09/27/14 04:30 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Anybody? Fuel sending unit for a '79 Dodge Magnum?
Re: Fuel Sending Unit [Re: Rob C] #1676151
09/27/14 12:41 PM
09/27/14 12:41 PM
75 ramcharger. reads empty. Is my sender the same (or wired the same) as the one in the pic? I'm assuming the black base threaded nipple is a ground & the red one is for the sender? Which wire at the rear bumper harness is for the (red nipple terminal) sender so I can ohm it?
Re: Fuel Sending Unit [Re: Yellow Fever] #1676152
09/28/14 08:41 PM
09/28/14 08:41 PM
Wisconsin
Wisconsin
I pulled it out and that is the wrong unit, will have to do some searching.
Re: Fuel Sending Unit [Re: Mopar_Mudder] #1676153
09/29/14 10:19 PM
09/29/14 10:19 PM
Wisconsin
Wisconsin
I found part number on it anyway, it is 3738891, can't seem to find anything with that number though.
Re: Fuel Sending Unit [Re: Mopar_Mudder] #1676154
09/30/14 02:15 PM
09/30/14 02:15 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I had this issue also. I did find a reproduction one for my car (65 Newport) but I have never had good luck with aftermarket or reproductions. I found a place in New York that specializes in restoring them. Cost seems to be reasonable. Quote over the phone sight unseen was 75 to 175 depending on work needed and they will call with a firm number upon their inspection. Place is called Tri Starr Radiator and located in Seneca Falls New York. Website is www.tristarrradiator.com
2 week turn around. I just sent mine in Monday so I can't report results yet.
