60 ft. time still stinks! #1675860
09/22/14 09:14 PM
09/22/14 09:14 PM
N.Y.
sixpacksteve Offline OP
N.Y.
my 68 dart 505 stroker ,5500 8" stall,dana 4:10 29.5 slicks. ladder bar susp. new qa1's all around. new drag torsion bars. just had professional alignment. 1.46 times. i should be in the 1.30's yes?
i've went up against conv. and took it to 1800 at lights. same thing.
any suggestions?
Hell Hath No Fury Like Mine
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675861
09/22/14 09:19 PM
09/22/14 09:19 PM
Toronto
mshred Offline
mshred  Offline
Toronto
any suggestions?
At what weight? What mph and e/t?
Re: 60 ft. time still stinks! [Re: mshred] #1675862
09/22/14 09:21 PM
09/22/14 09:21 PM
N.Y.
N.Y.
car weighs 3265 w/driver its been 10.07@133 mph
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675863
09/22/14 09:26 PM
09/22/14 09:26 PM
Toronto
mshred Offline
mshred  Offline
Toronto
car weighs 3265 w/driver its been [Email]10.07@133[/Email] mph
That 60' time does seem lazy...Are you sure the converter is flashing to 5500 off the line?
Re: 60 ft. time still stinks! [Re: mshred] #1675864
09/22/14 09:30 PM
09/22/14 09:30 PM
N.Y.
N.Y.
no trans brake, foot braking it. to about 4k
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675865
09/22/14 09:33 PM
09/22/14 09:33 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
It's the 4.10's that's killing your 60 foot. You need more gear. /like a 4.56
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675866
09/22/14 09:35 PM
09/22/14 09:35 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
It could be just a matter of your weight.
I'm running roughly the same MPH with less cubes (although on Alky) but my car is lighter then yours.
I also have 4:56's and 31" tires.
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675867
09/22/14 09:37 PM
09/22/14 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Take video of your passes... mainly the starting
line at a 1/4ing angle from the rear so you can see
the rear of the car and the front but mainly looking
at the rear tire and the body but yet see the front
tire... without any info its strictly a guess... do
you play on good tracks or just iffy tracks(what do
the other racers say about their 60')
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675868
09/22/14 09:41 PM
09/22/14 09:41 PM
Toronto
mshred Offline
mshred  Offline
Toronto
But when you stab it on green, is the converter actually flashing to 5500?
Im no expert, but I am also thinking that with those tall tires you might want a little more gear than 4.10...not sure how much more though
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675869
09/22/14 09:57 PM
09/22/14 09:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What RPM do you shift and what is the trap RPM..
have you measure the slippage rate on the conv... this
is to verify that the tack and the the numbers are right
Re: 60 ft. time still stinks! [Re: MR_P_BODY] #1675870
09/22/14 10:05 PM
09/22/14 10:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
What are the cam specs, and how much compression?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 60 ft. time still stinks! [Re: B3422W5] #1675871
09/22/14 10:30 PM
09/22/14 10:30 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If it is hooking I believe the issue is lack of starting line ratio. My car has the same issue, only with a quicker car. I run a 4.10 as well. The cars I race in N/SS that run 9.50/9.75 tend to 60 ft in the 1.25-1.30 range. My car is in the mid 1.30s on most days yet runs .30-.60 quicker ET. They all run 4.30-4.56
Doug
Re: 60 ft. time still stinks! [Re: dvw] #1675872
09/22/14 11:08 PM
09/22/14 11:08 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
My gen 3 hemi 1.45, 10.08 133
Re: 60 ft. time still stinks! [Re: sixpackgut] #1675873
09/22/14 11:17 PM
09/22/14 11:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Gear can definitely have an effect. I have seen firsthand a 112-114 Lsa cam on a motor without a lot of compression knock a good bit of 60 foot out of a car, compared to a narrower cam.
Might not be the case on the OP'car..
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675874
09/23/14 09:18 AM
09/23/14 09:18 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I would try foot braking it to about 2500 RPM to hit the converter harder...might be all it needs.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: 60 ft. time still stinks! [Re: FlyFish] #1675875
09/23/14 09:47 AM
09/23/14 09:47 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I had a similar problem to you, i changed from M/T to hoosiers and had to raise the tyre pressure by 3-4 psi to make it 60ft. I also went from single adj 9 way ranchos, my best 60ft with them was 1.43, to afco doubles, my best now is 1.39 but i go regular 1.40's.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 60 ft. time still stinks! [Re: mshred] #1675876
09/23/14 10:56 AM
09/23/14 10:56 AM
ill
dennismopar73 Offline
ill
any suggestions?
Going up gear will lessen the converter stahl not much improvement in 60 to be
found there.
I thing couple things are at play here.
Front end to tight , chassis set wrong in the back
Converter not what it should be or could be , carb issue not big enough or tuned issues
But a 500 cu motor in a 3200# car had best be a 9.70 car so something amiss here
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675877
09/23/14 06:38 PM
09/23/14 06:38 PM
gregsdart Offline
gregsdart  Offline
There is a lot of info missing here. Head type, and flow? trans type? Cam duration and installed at? The slow 60 ft could be anything from tie spin to pump shooters, wrong cam, and on and on.
Re: 60 ft. time still stinks! [Re: Sammy] #1675878
09/23/14 06:52 PM
09/23/14 06:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not true............I`ve been back to back 1.36`s w/4.11`s............
Re: 60 ft. time still stinks! [Re: sixpacksteve] #1675879
09/23/14 07:09 PM
09/23/14 07:09 PM
Lots of gremlins can affect staring line reaction times and 60 ft. times Which brand is the converter and was it made for your car or used when you bought it? What size squirters and cams on the carb? How much front end travel before the front tires come off the ground? some things come easy, with the right parts, and others take a lot of work to get the results you want, especially in race cars Just like women, some parts need more massaging befor they perform well Some need replacing to get the results you desire AKA, let us know the answers to the above ?
